P1000 What to service for the winter
A
Anthony277
Elizabethtown
I was looking for advice on servicing my Honda 1000. I plan on trying to change oil and filters every winter like I do on every other piece of equipment. I was curious if any one could share a detailed list on what all they do to service there machine. I have already had my initial first service done. Wasn’t sure how many spots should get greased or get attention..... I have watched several videos on changing the oil and clutch oil...... anything else you would change or grease after a year of riding in trails.
66,869
Hi,
Welcome to the club.
  • Oil
  • Filters both Engine & DCT.. Honda says every 1200 miles.
  • Check Air filter.
  • Check coolant, sub trans oil, diff oil.
    That's about all for common services.
every second year change.
  • Coolant
  • Sub trans oil
  • Differential oil
Things to check and grease
  • Ball joints - buy a needle for your grease gun and put some in, these are often overlooked.
  • Grease wheel bearings - There is a bearing greaser
  • Check a-arm bolts and bushings. Put a wrench on the a-arm main frame bolts and check tight.
  • Brakes.
  • Tie rods and tie rod ends for loose. Grease these too with the needle.
If sitting for a long time I would do the following.
  • Full tank of gas and add stabilizer.
  • Block intake tube to keep rodents out. (don't forget to unblock it)
  • Buy some rodent repellent and spray around.
What else?
Reactions: TripleB
A
Anthony277
Elizabethtown
This is
Hi,
  • Oil
  • Check Air filter.
  • Coolant
  • Sub trans oil
  • Differential oil
  • Brakes.
What else?
This is exactly the type of information I was looking for. And thank you for you input
Just follow the maintenance schedule.. only other thing I would add to Hondasxs’s list is your cable adjustments.
Is that E-town Ky?
A
Anthony277
Elizabethtown
Is that E-town Ky?
Yes right beside Glendale is we’re I live
Is that E-town Ky?
Pilotadam
Pilotadam
326
735
Pell City, Alabama
Hi,
  • Oil
  • Check Air filter.
  • Coolant
  • Sub trans oil
  • Differential oil
  • Brakes.
What else?
With the needle grease tip what are you greasing in the stock ball joints? Under the rubber cover?
