P1000m5 Whoops
tapakegovagnaps
tapakegovagnaps
30
34
NVA
Installed my lift the other night.
Took it for a second test ride.
Came to a culvert, so i put it in low, up and over as usual. Then we took of in a field at top speed, then noticed hesitation as I was about to let off.
Looked at my passenger and thought wtf?
Turned around and did it again, felt the hesitation while wide open, didn't sound great either.
I slowed down while screaming and thinking about warranty.....only to realize I'm an idiot and left it in low and was hitting the limiter!
So stupid, hopefully i didn't screw anything up!
Drove normally in high, as expected.
Don't make the same mistake!
sharp
sharp
3,757
14,955
Tennessee
Haha your fine that stuff happens all the time. The rev limiter protected the engine.
322,690
Just like Sharp said rev limiter protected. Definitely don't want to bounce off of it all the time but that's what it's for. You're good!
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I hit mine within first hour of use. Didn't realize there was a slight delay when shifting in manual. So I ran it to redline before hitting the paddles lol. Hitting the limiter with engine under a load is harmless. It's those idiots hitting it while sitting still that jack stuff up lol
Manwell
Manwell
803
2,439
I haven't hit the limiter yet, if all goes as planned I will get a few more miles on it and possibly an oil change before I take it there! However, I don't think it hurts the system. I remember back in my Gold Wing days I visited the factory twice up in Maryville, OH - they would crank on those Gold Wings before draining the oil and prepping them for shipment to the dealership.
Reactions: pct and Delton
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Yeah but back then a Goldwing's rev limit was somewhere around 5K lmao. We had a couple of 84's come in shop I worked at with the dreaded stator problem. 10 mins to replace stator but several hours to remove engine lol
Reactions: Manwell
Manwell
Manwell
803
2,439
I get it... But my point is everyone would baby the machines until they got mileage on them. Honda would be rocking them right out of the crate!
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
That's cause they built them right. After I freshened my race bike up with rings and rod bolts, I'd put it through 4 or 5 good heat cycles, then back that b*tch into the water box. Not an advocate of babying until broken in lol.
ToddACimer
ToddACimer
Pioneer 1005-2
3,673
15,526
Oshkosh, Wi
The rev limiter functions the same regardless of engine load.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Not true. Engine will turn quite a bit more rpm without a load than with. Sitting still on the limiter is very good way of breaking something.
After reading my reply, I realized it's wrong. Yes limiter functions the same. It just doesn't limit rpms anywhere near as well as under a load. And it's way more likely to cause damage. Usually floating a valve (for starters).
Reactions: pct and DGann
