Yes it has antifreeze.Does my 2022 1000/5 need to be winterized? It’s has antifreeze from the factory, right?
Pick yourself up a hydrometer and check your coolant. That will tell you the temp rating of your coolant, it's not a bad idea to check before winter in cold climate regions just to be safe. Amazon sells quite a few variations to check coolant temp levels.....Does my 2022 1000/5 need to be winterized? It’s has antifreeze from the factory, right?
Thanks! I will!Yes it has antifreeze.
Might pull the battery or throw it on a trickle charger though if it’s going to sit for weeks/months unused.
Thanks! That’s a good idea.Pick yourself up a hydrometer and check your coolant. That will tell you the temp rating of your coolant, it's not a bad idea to check before winter in cold climate regions just to be safe. Amazon sells quite a few variations to check coolant temp levels.....
