Resource icon
Dual Battery Install with TRUE Isolator
7,182
27,656
So I noticed, as JTW said some are running aux ground to main ground. Did anyone ever call the designer and find out if this is what keeps the blue light on all the time? Hooked mine up and the light has stayed on for an hour. That in mind I took the battery out of the box and hooked it up without trickle charging it first.
Yes i talked to him
The light will stay on as long as the voltage is high enough (circuit closed). When the voltage on the auxiliary battery drops down the circuit opens and the light goes off. (circuit open)
truc577
truc577
130
360
NEMO
Yes i talked to him
And it is all good to run the negative terminals together? As far as the designer is concerned?
I actually ended up running a 4 gage dedicated ground back to where the stock battery grounds to the motor. This way my entire accessory battery is as isolated as it can be.
Reactions: elkguide
Yup.. my dad ran his that way. Works fine... he doesn't have as much amperage pull as I do though. You can't have too much ground so, do what works for you!
Reactions: truc577
truc577
truc577
130
360
NEMO
But I didn't design this isolator and it may be more sensitive than I understand
7,182
27,656
If you google search the True isolator, you will fimd a # in Washington state . I think thats where it was! If you call it the designer/ builder/seller will !nswer the phone. Hes a great guy to talk too. Make sure you have plenty of time to listen!!!!
Reactions: JTW
I grounded both batteries together. Then grounded the auxiliary battery to the frame. Like y'all say, can't have too much ground.
CP: This group looked for anything rough and had a great time. It wasn't all about who was the best or correct line just some good ol boys with a beer and a 4wd.
Reactions: Tramguage1
320,748
So instead of running the aux ground to frame can't you run it over the ground on the main battery?
I'd do both. Factory ground isn't the best and solid ground is always better
Byrdman
151
215
Kentucky
I'm about to wire my isolator up. Is it ok to take the ground wire on the isolator and run it to main battery negative? The main battery negative should be grounded somewhere on motor or frame correct?
7,182
27,656
That sounds correct.
Rocket
Rocket
Rocket
281
930
Bullard, Texas
THANK YOU FOR THIS THREAD!
i INSTALLED EXACTLY (GROUND WIRE FROM TRUE TIED WITH FACTORY GROUND)...
Muleyhunter
Muleyhunter
34
49
Lake Kiowa, TX
Okay, I was just about to hit the buy button on the PC925 Odysey battery when my inner self told me I better check the dimensions. I've found a couple of different measurements for it but basically 6.75x7x5 which seems like a very very tight fit in my aux battery location. I have a 20017 1000-5 deluxe. Has anybody had any problem getting this battery to fit in that compartment?
Reactions: BWAF
13,474
66,484
I believe the 925 is a common item to be installed in our machines.
We also use a mighty max knock off.
