P1000 Looking for replacement screw on two-piece honda windshield
A
AdamSG
22
Louisiana
Hey everyone, I just recently bought a brand new 2023 1000-3 Pioneer Forest edition.
The dealer installed a nice accessory package, including a two piece windshield.
On the very first weekend I used it, it appears that I lost one of the the bolt, top hat washer, and nut for the lower windscreen section. There are 4 of these for that lower part. The attached pic is from one of the other of the 4 I took off to show everyone.
Is there an easy way to order a replacement for the bolt, washer, and nut? I called the dealer, but they made it sound like I would have to order an entirely new kit, which seems ridiculous.
Thanks for the help!
Honda screw
Reactions: TxDoc
64,628
Sorry might be SOL.
See link. Looks like part #18 with is listed as N/A. I'll see if I can find anything else tonight.
109,542
Welcome from Michigan.
Got Pics of the rig?
#POIDH
bumperm
bumperm
1,856
6,671
Gardnerville, NV
That looks to be a rubber "well nut", here's an example of an M6 size:
Well Nut
You may need to do a bit more looking and make sure I'm right. Cheap enough to replace all of the ones you have left so they look the same.
The basic idea is they go into a pre drilled hole, then when the screw it inserted and started to tighten up, the rubber expands and locks the nut in place. They are removable (as you found) and easy to use, also handy to have around the shop (usually in smaller sizes for to mount stuff. :)
ODAMO
ODAMO
1,202
3,263
1695553385970
Take a look at Well Nuts at McMaster Carr. They have everythang.
Reactions: Scrappapotamus
