P1000 Need help
Status
Not open for further replies.
Skeeterfx20
Hallsboro NC
Hello I'm new to site, just bought pioneer 1000-5 deluxe 200 miles showroom condition! I'm not mud seeker just love riding kids, however I'm hearing a loud popping sound like somthing is in bind coming from rear end? It's at low speed 1-3
Mph and when I start to accelerate! I heard changing rear diff fluid would help somethings but not sure. If I do need change fluid what is best recommended thanks?
320,750
Popping sound I don't like but people have different explanations. Amsoil 75-140 is great.
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,569
Greenville, Mo
Might check your cable adjustment.. diff lock may not be fully engaging/disengaging.I think it was @snuffnwhisky that was popping out of lock at RRB.
Skeeterfx20
Hallsboro NC
It sounds like diff trying to engage and disengage could be the issue! Is that procedure hard to do?
Crow_Hunter
Crow_Hunter
750
836
Riding a Canned Ham.
I have had to adjust mine 3 or 4 times and when it was out pretty bad the first time, it would pop like that.
The procedure outlined in the manual should work, but sometimes it will get you close but you may have to make some further adjustments to tweak it in.
A great way to check it is to put it in Neutral (on level ground ;) ) and then shift it between 2WD and Turf. When it 2WD the cable going to the rear diff needs to be loose and kinda floppy, when in Turf it should be tight with no play. Shift back to Park (where it should also be loose) and make your adjustments.
It might take some tweaking to get it right and you may have to tweak some more after the cables stretch further, particularly after you go for a long ride.
Skeeterfx20
Hallsboro NC
Thanks guys for the help, I'll be back home Wednesday from work and I'm going straight home work on it
Reactions: GlockMeister
Brett002
Brett002
257
865
Bangladesh
@Skeeterfx20 Did this fix this issue? I have a 16' P1000-3 and seems to be having these same issues. I can shift to H or L or R and move maybe 5 foot and I hear a pop from driveline. After the one initial pop it no longer makes the noise again until shifting to a different mode.
Please anyone chime in if you know anything regarding this. Really trying to not give the stealership my cabbage if it's just a cable adjustment.
Brett002
Brett002
257
865
Bangladesh
@snuffnwhisky @crow_hunter @drfubar @CumminsPusher @GlockMeister @Delton @JACKAL
I really would appreciate the help guys. I'm sure this community you all do so much for around here appreciates it too. A lot of pioneer knowledge in those "@" tags!
Neohio
Neohio
Beast of the East
13,477
66,519
Painesville Ohio
@Brett002
Please start a new thread and we will chime in to help you. Dragging up OLD threads just serves for confusion. Feel free to link the thread in your first post for research.
Edit, Start with watching the videos posted and making adjustments.
Status
