P700 P 700 2019 OIL CONSUMPTION
Jerryg
Jerryg
10,808
87,197
NEPA
Your dealer won't rebuild engines?
Then what f***ing good are they?
It's probably not because they can't but it's just not worth it to them.
We would only do them over the winter, jut too time consuming.
Reactions: Robobrainiac
Robobrainiac
Robobrainiac
2,469
8,613
This is how it is where I work for GM. Rebuilding engines or transmissions is not worth the labor. The warranty coverage works differently as well. A rebuild covers only the parts you installed/used to fix the issue. While a reman/new gets full coverage of the complete unit.
Typically for just a little more than a rebuild and labor you can acquire a reman/new with labor for the swap and have a full coverage/better warranty.
Reactions: Jerryg
HondaTech
Nope. Wont do an engine swap either. I inquired about both. They will put on a windshield, roof, and back panel for $200 though (that is the price the quoted me when I asked to quote parts). Oil is cheap, im probably going to just keep adding for awhile.
Sounds like a bunch of parts hangers and wanna be techs.
We'd be out of business if we didn't do engine work. I've rebuilt 3 this year alone and multiple more last year. These are the only ones I have pictures of
20230408 160229
20221217 151944
20220726 163343
20220526 170628
20220201 175749
T
thatguy2
354
2,318
Kansas
They did tell me he was bored and got me in quickly when I called and asked. They sell alot of units as our sales tax is the lowest in the state.
T
thatguy2
354
2,318
Kansas
Is there a recommended aftermarket manufacturer? I am looking on summit racing and rockymountain atv currently but if you have a link to something that has worked for you let me know. Spent all weekend working on our wildland fire engines and tenders. Its 111, extreme drought, and 20% rh so gotta be ready to roll.
Mnjr
20
39
Mammoth Spring, Arkansas
Mine is also using alot. No leaks, no white smoke, etc for me. It has the local honda dealer baffled. I am not the only one they have seen like this. 2015 700-4 with 3000 miles on it. Ive been looking at forums. Some guys say a rebuild helped. Some say it didnt. Seems about 50%/50%. Ive done all the required maintenance since new with Honda parts and oil bought at the dealership. I roaded it to the dealer for my oil change this am. Unbeknownst to me it only had 1/16 the required oil in it. Probably lucky I didnt shell it out.
Mine started using A LOT of oil around 3200 miles. Never saw smoke and no leaks. Dealer wanted $1500 for "top end" service, valve job extra. Stumbled on to guy who did it for me and I supplied parts. Like he said, the valve seals suck. I found "racing type" Honda seals (whatever that means) on Ebay. I bought the engine kit on Ebay also, knowing it was Chinese made (aren't they all?). It was about $300+ cheaper than the dealer's price. Changed the oil after 100 miles and going on 300 without using a drop. I would have used a gallon EASY if I didn't have the repair done. My buddy has one a year newer, same problem. He bought the same kit and seals. No more problems. Like the other guy posted, if the job is done correctly there should be no more issues. Honda has a problem that they won't recognize.
HondaTech
Valve seals don't cause oil loss. Sorry but they don't
Most power equipment engines don't use valve seals and they don't consume oil either.
T
thatguy2
354
2,318
Kansas
What parts do I need to order to fix this issue?
DRZRon1
DRZRon1
867
2,816
PA
what’s wrong with it ?
DRZRon1
DRZRon1
867
2,816
PA
depends on if cylinder is worn, etc.
hard to provide help unless there is data, torn apart and measured, inspected, etc….
generally can’t go wrong with oem parts
