Polaris pulse bus bar in a Honda?
kaspar139
kaspar139
37
98
Conroe, TX
Has anyone used or considered adding the Polaris Pulse Bus bar? I must be missing something, but it seems that is you use the pig tails that easily plug into the bus bar you get the value of an integrated relay (perhaps???) in the pigtail that has a hot, ground, and key on hot. TOTALLY possible I am misunderstanding how it would work, but if you run from your battery the hot/ground to the bus bar, plug in a pig tail and run to your accessory, that you could use the always hot or key-on hot. Am I way off?
Bus bar: https://www.amazon.com/dp/B07W3QFT1N/?tag=sxsweb24-20
Pig tails: Home Page - SuperATV
Thanks for input/thoughts.
Reactions: TripleB
kaspar139
kaspar139
37
98
Conroe, TX
Answered, partly, my own question with more info. there is a third "key-on" wire that needs to go in to the bar as well. The pig-tail then allows you to pick.
Hope it helps someone.
Reactions: TripleB
TripleB
TripleB
11,932
101,132
Caryville, Tennessee
It would probably just catch on fire. Just kidding. I have no idea.
kaspar139
kaspar139
37
98
Conroe, TX
I am all about an adapter... was looking to "simplify" the wiring process. Like most things, no silver bullet.
Reactions: TripleB
