![kaspar139](/data/avatars/m/39/39463.jpg?1622219476)
Has anyone used or considered adding the Polaris Pulse Bus bar? I must be missing something, but it seems that is you use the pig tails that easily plug into the bus bar you get the value of an integrated relay (perhaps???) in the pigtail that has a hot, ground, and key on hot. TOTALLY possible I am misunderstanding how it would work, but if you run from your battery the hot/ground to the bus bar, plug in a pig tail and run to your accessory, that you could use the always hot or key-on hot. Am I way off?
Bus bar: https://www.amazon.com/dp/B07W3QFT1N/?tag=sxsweb24-20
Pig tails: Home Page - SuperATV
Thanks for input/thoughts.
