P1000 4+3 offset
Fletcher6291
Fletcher6291
Tennessee
Been a while since I posted and finally wore my stock tires down enough to justify buying new ones. Today I ordered a set of system 3 14x7 wheels with the 4+3 offset. Was wondering if anyone else is running the similar offset on all 4 and if your running spacers on the back
107,956
Not a similar set but going same size all the way around you WILL need spacers to fix the trac or you will look real goofy going down the road
107,956
read the last couple posts
Fletcher6291
Fletcher6291
Tennessee
So from what I’m gathering, he’s basically getting a 3” offset with the added spacers. So running a 4+3 is getting the same result just less parts
Reactions: Bama-Daniel
107,956
@Fletcher6291
You can say that yes. But without spacers will have to get two different size wheels for the front and back or your track will be off. So again, better off just getting the same size wheel, offset and all of your choice to be able to rotate and or have the same spare. And the appropriate spacer to got with.
JenElio
JenElio
65,528
612,471
Loxahatchee, florida
It's not a problem, you'll need either a 1" or 1.5" spacer for the rear wheels if you want to keep same wheel track. Other then that you shouldn't have any issues.
Ohhh and you'll probably get a more splatter on the side/inside of your machine since the wheels will stick out further but you can always get some kind of guards for that as well........let the spending begin!!!😂😂😂
Fletcher6291
Fletcher6291
Tennessee
@Fletcher6291
Thanks for the help. I figured I’d have to run 1” spacers in the back. I see where everyone runs 5+2s and was hoping I didn’t mess up ordering 4+3s. But I feel better about it. Pictures to come in the next few weeks. Now to do the endless research on tires!
Fletcher6291
Fletcher6291
Tennessee
If you’re not gettin dirty are you even doin it right? Lol.
107,956
Unsolicited advice on that….
Just get what you think will work and looks BA to you! They all ware very differnt depending on the driver & terrain your driving in. So when I say my LT’s have been great! They would look alot better if i just drove roads.
Fletcher6291
Fletcher6291
Tennessee
Just get what you think will work and looks BA to you! They all ware very differnt depending on the driver & terrain you’re driving in. So when I say my LT’s have been great! They would look alot better if i just drove roads
Living in East Tennessee, we’ve got a little mix of everything. I’ve really been impressed with the stock bighorn 2.0s. 2 years and 1600 miles and could probably get a third year out of them, but I also like the Sedona coyotes
Fletcher6291
Fletcher6291
Tennessee
28x10x14 Sedona rockabilly on Sedona wheels. And I see what everyone says about the wheel spacers. I’ve got 2 -1 1/4 ordered
609561A2 E4DF 400A B240 5EE54D70D8B8
