P1000 Forwards AArms and Shocks P1000
Scamih
179
455
Marshall Illinois
Ok, NOW you've got my attention ..... tell more about your tree cutting level ...
I noticed that my notch and my backcut was always crooked when I compared it to my logger buddy so I started using a level with a magnet on my bar to get those 2 cuts started straight. Makes a big difference. I think I invented it or I am the only tree cutter that can’t make a straight cut. It is definitely safer when dropping a tree. I heat my house and shed with a boiler. I drop about 6 trees a year. It really makes a big difference on big trees.
P
packer58
306
925
N. Cali
Gotcha, i figured it was something like that.
Scamih
179
455
Marshall Illinois
I took it on a long ride yesterday on the road and ended up on some muddy wood trails. Front shocks are definitely better, back shocks are a little stiffer since I raised it up.
DCD91500 1D8F 49C2 AC08 06C57BD8139B
Scamih
179
455
Marshall Illinois
I got super atv and rough country shocks and 30 inch tusk aramid terrabites on. Front and back. So far I like it all. Shocks are a lot better than stock. During the job I found a broken brake mount that got fixed. I had to adjust the back shocks and add preload to the back to level the machine out. I used factory preload on front. My alignment is close but I’m going to drive it for a while and then check it. Thanks for you guys that gave me feedback along the way.
IMG 2569 IMG 2568 IMG 2565 IMG 2566 IMG 2564
P
packer58
306
925
N. Cali
Looks awesome for sure ...........but damn, you really need to center up your winch hook in the fairleed ... just say'n ...
  • Haha
Reactions: Scoop
Scamih
179
455
Marshall Illinois
Seems a little knitpicky, I didn’t know you were supposed to center it. I cleaned it after last mud hole adventure and wrapped it up going back and forth and that’s where it stopped.
Scoop
Scoop
4,278
16,031
  3. Talon R LV
You do you and that's all that matters, @Scamih ... 😉
P
packer58
306
925
N. Cali
Just poking a little fun ........ only part i was serious about was your good looking machine ....
Scoop
Scoop
4,278
16,031
  3. Talon R LV
Just for you packer 58
Use the @ sign before a username and it will let them know you tagged them.
Gotta be the right name - there are no spaces in @packer58.
As you type, it will pop up suggestions after you start typing the @ sign and the first part of a username - when you see the right one, just click it!
Screenshot 20230723 094515 DuckDuckGo
Once you post your message, if you see thier name is a hyperlink, you know you did it right!
P
packer58
306
925
N. Cali
Dang, i'm not sure if i'm feeling special right now or just being made an example of ............ :oops:
  • Haha
Reactions: Smitty335 and Scoop
Scamih
179
455
Marshall Illinois
Another tip for buying these Aarms, vendors on eBay will offer used Superatv arms. Most of the time people order the wrong stuff and return it and that’s how used it is. I got front and back sets for 250 each.
