![Scoop](/data/avatars/m/44/44333.jpg?1717614999)
Scoop
Touché! 🤣What a surprise 😆
Thanks for the heads up… they should remove them and save me $1…These little plastic wings that come on the trailing arm guards will rip off, so don't fret
Trail will do it and take your $1Thanks for the heads up… the should remove them and save me $1…
And what the hell does that metal piece even do?These little plastic wings that come on the trailing arm guards will rip off, so don't fret
Protect that rear trailing arm ball jointAnd what the hell does that metal piece even do?
Good to knowProtect that rear trailing arm ball joint
You sending someone to pick up your “building” materials?You might make the TO yet without a trailer load of boxes! 🤣
Can you take a closer picture of the damage to those tree kickers for meI'm ready beotch!
I don't have any damage. Just paint, but I just hit it with bed liner spray and it blends right inCan you take a closer picture of the damage to those tree kickers for me
Thanks … scratches mostly on the lower outside edge or bottom?Other side
Are these the tires and wheels you are going to use or do the new ones have more offset?Here are the updated pictures … it seems the skids don’t extend any farther than the trail arms do
View attachment 428112View attachment 428113
Those are 6+1 and new ones are 5+2…Are these the tires and wheels you are going to use or do the new ones have more offset?
Skids don’t take up any additional space toward wheel than standard trailing armAre these the tires and wheels you are going to use or do the new ones have more offset?
So you’ll gain almost an inch of clearance depending on tire.Those are 6+1 and new ones are 5+2…
