Under Hood cheap storage
bfair
bfair
56
Here is a cheap under hood storage at Walmart.
Box zps8c8c5562
http://www.walmart.com/ip/Snapware-Heav ... 6/26441686
Model No.: 1111986
Product in Inches (L x W x H): 15.5 x 11.5 x 5.63
Walmart No.: 551212496
BigRiver
BigRiver
324
79
Yes, definitely a good storage box. I'm currently using a Stanley tool box from Walmart, but have out grown it already.
I recently picked up a small 12 volt compressor, but found that it's slightly too big for the box.
Thanks for posting this up!
b4hntn
58
11
texashuntinglease.com
I picked up one at Wally World today. Looks exactly the same but is too tall. Don't get the 9" tall one. I'll try again. Nice box.
bfair
bfair
56
Walmart No.: 551212496 Hope this helps.
Clarky
108
It even matches your paint scheme. Do they sell a camo box?
Elkhunter
Elkhunter
345
453
Minnesota
Do you fasten it down somehow spit dosent move around ?
bfair
bfair
56
It seems to fit tightly, the hood seems to hold it in place. If I need to I will use a buggy cord.
sksshooter
79
im really hopeing that someone comes out with a front rack. ive seen them for other sbs's where they detach from the top fairly quick to fold down to access under the hood. I have a kolpin dry box on my atv that I would really like to mount on a front rack.
b4hntn
58
11
I went back and found a 6" high one under the others and it fits.
zrxrob
zrxrob
41
5
I'll be at Wal-Mart tomorrow! Thanks for the info
zrxrob
zrxrob
41
5
Couldn't find that exact box but found a clear sterilite box with the same dimensions for $6
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
They do make one, looks cool too I think. - http://fuse-powersports.com/products-pa ... -rack-kit/
scott
scott
1,212
1,354
lyman, South Carolina
I like that front rack and have seen it before. I was hoping it would holds more weight 80lbs is it. There has to be a way to brace it better and be able to hold more weight. Maybe go through the plastic and make a brace from frame to under rack or go from the hinge point from where to connects to rack and do a brace higher up on roll bar. Cause nothing is holding it in place very good. That bar from roll bar to rack is going to be the weak point. It's a good start but i think it needs to be improved.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Yeah I think if it connected at the roll bar then followed the body line on the fender and tied into the front bumper (similar to an exo-cage)it would be plenty strong enough for more than 80 lbs. Might have to break out the welder...
That one you posted looks like it would be stronger. Too bad there's not a full picture of it installed
JasonS
14
I found the attached soft tool bag at Menards and it's a perfect fit. Pls see pic.
