1000-5 Front Fox 2.5” Springs
Scoop
Scoop
4,250
15,926
  3. Talon R LV
If my fronts weren't for a 1000-3 (I was replacing with linear springs, so it didn't matter), I'd have you covered. Sorry. :(
Robobrainiac
Robobrainiac
2,470
8,628
Scoop
Scoop
4,250
15,926
  3. Talon R LV
I am curious your desire for progressive rate on a trailer.
IMHO: When you load the trailer, it's not always equal side to side. The progressive rate springs will help to keep it even better than a single rate spring, albeit at the expense of compressing a bunch of the spring(s) before you even move. Also helps when you're going over rougher, uneven terrain. Finally, the progressive rate springs do make for a better pulling unloaded trailer.
IIRC, Dodge and some other truck manufacturers who put coils on their trucks used linear rate springs, but many people swap them out for progressive rate springs. The manufacturers may have changed that up now, not sure.
Just my $0.02. I'm no suspension expert, but I did stay at a Holiday Inn Express last night. :p
Robobrainiac
Robobrainiac
2,470
8,628
Makes sense to me.
NewHere2
NewHere2
Village Idiot In Training
36,366
308,493
High Plains of SD
Built lots of trailers thru the years. Tried shocks with linear springs and noticed an improvement. Never tried one with progressive springs and shocks.
My last hunting / over landing trailer had 200 lb linear springs and shocks. It was excellent for 3 - 200 lb deer and equipment. Loaded an elk in it and it bottomed out bad in rough terrain. I estimated the elk at around 1100 lbs.
Thought I’d try to get the best of both worlds. Something that would handle 600 lbs of deer and gear. Then be able to handle an elk.
Robobrainiac
Robobrainiac
2,470
8,628
Sounds good to me. I like the logic.
Scoop
Scoop
4,250
15,926
  3. Talon R LV
Linear shocks can handle the sheer weight - evenly distributed. But when it's under load or moving across disparate terrain, you'll notice the shortcomings.
Most trailers have leaf springs, and most leaf springs are progressive (from what I recall reading).
Am I getting any of this right, @Smitty335? :D
ChadD
ChadD
23,273
233,249
Brown City
P.O.I.D.H
😉 #NTC
208,029
Never ran shocks on a trailer, so I don't know? I've always wanted to try a trailer with the torsion axels though.
