P1000m5 1000-5 Rear Door Inside Storage Modification
39,079
Finally got some time home and finished this project. Well, almost finished. Still waiting on the thumb screws. I’ll do 2-3 per door and that should be enough.
Passenger side panel. If someone cared they could color the rivets.
Feb3946cea7ec48f3e279531ba9cd118
Rivet up top for the chain.
26faed99bd9a2ac0de92f0f76948c574
Not too bad.
8194ec87f6b0ef3fdee4eb8cb6109e26
This is what I fit in the passenger door.
86e6b9399b3b6f4d03acb0c97ad19635
1c6bf8d5fb5bd0191766cc32bc1d57c6
Driver side
50cefe10c1b5644b44cbd3323a20298d
39,079
Thoughts:
It’s easy to get to. In the past I was required to remove ratchet straps or bungees that held the boxes down in the bed. Now it’s just a couple thumb screws and dig for it.
The hinge needs washers for backing inside the door.
The hinge needs spacers between the colored panel and the hinge. I used some small #10 nuts.
I bought 10 thumb screws. I’ll keep extra in the glove box. Extra could be used for trailering.
sharp
sharp
3,757
14,955
Tennessee
Thoughts:
I would double bag the toilet paper.
39,079
Happy to see the piano hinge worked!
How is the door function/swing with the added weight?
Thanks for the input, it works great.
As for the added weight, it’s no problem. The Honda hinges are beefy and actually the door now sounds more solid. Time will tell if it causes an issue but I doubt it.
39,079
The thumb screws arrived. I think it will work good. I bought six, two for each door and two spare in the glove box.
0ca786729c37c6e67cb9556e5a4f451e
I cut some of the screw off so I didn’t have to thread it so far. Then I used a shoulder nut so it captures the plastic.
Bf86c84d17271cd4b5a81c216b8570b7
39,079
The shoulder nuts have loctite on them.
Here is the pieces I bought. I thought these would have less chance of hanging since they are round versus a wing nut.
D4d57c9b120cb948721e84b5cc3cf4da
The 16mm length would be better as I had to cut the 20mm length.
Decided to copy @joeymt33 door mod and I cut holes in the rear doors. Wow those things are cavernous. All the gear I usually carry in the bed can now be stored away in the doors once I get different storage bags that fit better. Hopefully it stays cleaner, the extra gear weight is much lower, doors don’t rattle, and the bed is free to be cargo or people much easier than before when I had to rearrange everything or pile stuff on top of other stuff.
The ONLY a downside I see is if I am leaned into the door panel that has my recovery gear stored in it. I may keep a short tree saver and block in the glove compartment.
I ended up mounting the stainless hinge to the plastic panel first. Then remounting it to the door taking a piece of masking tape and lining it up along the bottom side of the hinge marking each end then removing the panel and lining the hinge up so that it was in the same place. A few rivets later and she’s done it was quick, maybe 30-45 mins.
AE3B59A8 4B1B 4E9C 8CF5 90B1B1A8A46B 432BF75E 4215 4930 B370 7FE546086165
1000-5 Rear Door Mod
[HASHTAG]#doormod[/HASHTAG]
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
View attachment 75406 View attachment 75407
I am going to have to do this, that is just too much wasted space not to take advantage of it.
After watching Joey “clown car” stuff out of them I knew I was gonna do it when I got home. It was amazing how much space is in there. I feel like I should fill them up. One side will hold what I carry with room to spare, the other is going to get the water pump and some other things I don’t carry because of lack of space. I may even move my tools out from under the seat.
I was considering making a bed storage box but now I don’t think I’m going to because of all the space.
I think I’m going to be in the market for a bed extender and modify my spare carrier slightly.
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
Do you think a scissor jack will fit in there? I have pretty much decided this is the route i want to go as well
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
I think so I don’t have one to try though.
I held mine up to it and it looked like it would...its the only tging i questioned getting in there so i can eliminate my huge toolbox
Reactions: BWAF
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
@joeymt33 gets all the credit for that one he had the awareness to try it and the guts/stupidity to cut a gaping hole in a door.
Yeah I know. The man deserves an award for sure. He should start making and selling them. Trim out the hole and put a custom logo on the panel. BOOM! I wondered if you could stick some flexible insulation to the inside and put a plug in the bottom you would have a hidden cooler. @joeymt33
I have a 4x8 sheet of ¼" HDPE I'll give him to attempt it...
Actually thats a really good idea, I wonder if a plastics shop could heat some HDPE and after putting insulation in there, make it fill the space? then have a gamma type lid to seal the cooler. Need a drain somehow.
Reactions: Remington and BWAF
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Crap before I start on the tailgate cooler rack I may try to get a volume guesstimate of the empty door.
It's a little crude but after insulating you could use a large waterproof stuff sack. Put it in the hole then fill with ice and drinks. When you're done you can pull ice and water right out the hole.
Reactions: Abuck and BWAF
39,079
And I will pass some of the credit to CP because he was the inspiration with his tailgate storage.
