P1000 1000-5 steering rack replacement
Bones
199
203
Bourbon Mo.
Has anyone changed the steering rack (box) in a 1000-5? I am having a heck of a time removing the upper bolt on the passenger side. Suggestions welcome.
Thanks
208,024
Thanks
Can you get an impact wrench on it?
Reactions: EMAW and TxDoc
Bones
199
203
Bourbon Mo.
No. It's nutted to the firewall side. You have to take that little access plate off and can barley get a 14mm wrench on it...and 0 leverage. I did put a impact on the other end while my helper held the wrench but had to use a really long extension and a swivel. Didn't budge. Another real obstical is the hard plastic breather tube. Exactly in the way and only a finger width between it and the nut.
TripleB
TripleB
11,937
101,372
Caryville, Tennessee
Screenshot 20230903 125019 Brave
Here is the instructions I was given the first time doing it.
Reactions: Smitty335 and EMAW
Bones
199
203
Bourbon Mo.
TripleB,
I removed the access door and have removed 3 of the 4 bolts. My problem is the upper bolt on the passenger side. I can get a 14mm on it but there is no leverage to be able to turn it. You mention instructions in your reply. Did you mean to post a link? Or, just describing the process in the body of the post? Thanks for the tip on the EZ mount.
TripleB
TripleB
11,937
101,372
TripleB,
It was just a screen shot of a private message someone sent me years ago.
Bones
199
203
Bourbon Mo.
I see. This video is what I used for instructions. This last bolt is being a pain.
Bones
199
203
Bourbon Mo.
Ok. Finally got it broke loose from the outside. Long ratchet and a strong buddy helping. Then to hold the nut on the inside I used a 9/16" distributor wrench I found in my toolbox. Strongly recommend the distributor wrench or a really offset box end wrench to get on the nut on the inside. TripleB, I ordered the EZ mounts. Thanks for the tip.
IMG 44641
