16-21 Front upper control arm repair kit Pioneer 1000 All variations
Bighat
Bighat
876
3,744
Gallipolis Ohio
I only have about 900 mile on my machine. Why do you say I will need this kit? What does in correct or fix? Do these machines have a problem?
Reactions: Backwoods and ChadD
Neohio
Neohio
Beast of the East
13,475
66,489
Painesville Ohio
No set mileage for the upper a arm holes to egg/elongate. Every machine is different.
The holes typically wear faster if you change from stock arms to aftermarket on the 16-21 models.
I have a 16 with roughly 3000 miles on it. I am starting to get a wandering feeling when driving it at moderate speeds. I have some shop time scheduled later this season to inspect my machine to see where the wander is coming from. Right now it is used as a glorified golf cart at camp. No real danger going under 10 mph.
Do they have a problem?
Too many variables to give a concrete answer. The single bolt upper is a problem that has been addressed by Honda for the 22 machines. They went from a single 10mm bolt, to a dual 12mm bolt. It is also common for the welds to fail holding the tabs to the frame. I am working with my laser fab guy to get some different bracket options designed and cut. That is longer term though.
Russ989
Russ989
22,601
146,866
Yep, been there and done that.
CB39F6E1 AEC2 4B6E B578 5608A62AA5AE
1A31C516 9832 44F1 BF2C 17A1BFA53B27
ToddACimer
ToddACimer
Pioneer 1005-2
3,569
14,656
Oshkosh, Wi
Quick fix for chores but picked up the steel to make gussets.
I like using 2x2x.125 wall square tubing and you cut a 45° piece off for a nice 90° gusset. Mark the bolt hole in the gusset tab and then weld the washer on before welding the gusset to the frame. Also make sure there's a vertical weld on both a-arm tabs to the frame. Seems Honda missed that weld or didn't go the full height behind the a-arm pivot
PXL 20210714 140024352
PXL 20210714 141504971
PXL 20210714 141501133
Bad_Kharmah
DMV
What are the metal specs for the washers with this kit?
