P700m2 18w work lights?
sek-hunter
sek-hunter
306
574
I am gonna install a couple of 18W 4" lights on the back of my P2. I don't have to run these with relays do I? Just an inline fuse? What size fuse?
321,218
No relay necessary, if you run off of reverse switch then I would. 5amp fuse should be about right.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
I don't run a relay with any of my LED lights. @CumminsPusher taught me you divide watts by volts to get the correct fuse size.
So two 18w lights is 36w/12 volts = 3 amp fuse.
Did I get it right CP?
Reactions: CumminsPusher
321,218
Perfect! :):)
Reactions: Tflynn
Gator
Gator
The Most Unknown Member
2,476
10,399
Louisiana
That is the right way to calculate amps. Just remember that if you are running 3 amps all the time, on a 3 amp fuse, you will likely get nuisance tripping. By going up to a 5 amp fuse, you won't be on the ragged edge of burning the fuse all the time.
