P700 '19 P700-4 Mods.
Backwoods
Backwoods
32,396
332,528
Douglasville ga
They are not as bright as a 40" bar but for round LEDs mounted to a bumper I think they are good.
Definitely brighter by a fair margin than the stock headlights.
Here is a really crappy video but you will get the idea.
That's definatly an improvement over stock. My 12 inch light bar does good but when replacement time comes I may try the round lights. I like the look of them.
Glock21user
Glock21user
" Nothing succeeds like excess "
1,825
9,092
Livingston county, Mi.
Got the panel wired now time for heat shrink and wire management then install.
20200206 141645
20200206 140802
Glock21user
Glock21user
1,825
9,092
All heat shrunk, routed and tied down securely.
Now time to install and tie into the relays and fuse block.
Thank you @ToddH I appreciate your comments for sure. Are you going to be in Swartz Creek shoot btw?
Looks good and like your moving right along. What's your next mod ?
I have a set of P1 shocks coming, then I have an ARB air compressor and 2.5 gallon stainless steel tank sitting in the barn to mount along with a rear winch.
Then to mount the new tires. They are the Kenda Bear Claws in 27x11-12.
I appreciate everyone's comments and likes, it is definitely a motivator.
20200206 155132
20200206 155056
20200206 155047
Todd627
Todd627
56,365
615,700
MI
View attachment 182485View attachment 182486View attachment 182487
Yes, we will be there all day. We are running half of the tournament for Swartz Creek. They do not have the equipment or volunteers to run both sides of The Cage so we are doing one side for them. See you there 👍 🏹
FYI....that looks freakin professional!! Awesome job!
Glock21user
Glock21user
1,825
9,092
Thank you sir, very kind words.
I suppose some of the hours I have spent wiring control panels has worn off.
I will be there to help if you need it, otherwise we will see you Saturday.
Reactions: Mudwing
Backwoods
Backwoods
32,396
332,528
Douglasville ga
Let us know how the 11s work on front. Its going the nice when your finished.
Backwoods
Backwoods
32,396
332,528
Douglasville ga
Thank you,
Most certainly I will.
I am not fond of narrow up front and wide in the rear.
I wanted to go same all the way around I think it looks good but I wasn't sure it would work. I have tens on back but after I put them on I saw it more than likely would have been fine.
Glock21user
Glock21user
1,825
9,092
I will most likely get to the tires in the next couple of weeks, right now the front end is pulled up with the crane so I can do the shocks.
Glock21user
Glock21user
1,825
9,092
So I have now about 2 full days of driving around with the exhaust tip both towing a small muck trailer and not.
The sound is much deeper and throaty and it may just be me but I feel like it is more responsive all around.
It is not too loud and with the trailer possibly because I anticipated it could be an issue I turned the tip slightly and cut a small angle on the bottom so the sound doesn't bounce off of the trailer and reverberate.
Overall I really like it and most likely will keep it on.
If any issues creep up later that I did not expect I will update this post.
Glock21user
Glock21user
1,825
9,092
I will be done boring everyone with the wiring of everything as that is now done.
Everything works as it should, the only thing left is the bolt down the switch panel.
Now on to other projects.
I am certain that pics will follow.
20200211 172516
20200211 172501
20200211 172401
20200211 172256
20200211 172212
20200211 153945
Glock21user
Glock21user
1,825
9,092
Crap I forgot, I made a simple circuit so the backup light triggers when you put the machine in reverse or with the manual override switch.
And a simple lockout circuit for the manual winch control so it does not get triggered by fat fingers or curious kids.
Russ989
Russ989
22,578
146,647
Similar threads
brantpalmer
Replies
Views
2K
brantpalmer
Replies
12
Views
2K
Replies
9
Views
2K
KevP700-4
K
Replies
Views
989
toddvdh
