Multi 2 way radio mount success
Mudder
Mudder
NTC Ambassador of Walls
11,348
84,458
Trial fit between front roll cage and OEM roof too tight. Already have music radio in Glove box. Any examples? Was trying to mount it to minimize direct spray when washing, but under dash by 12v plug seems ideal. Maybe 12v socket plug for quick removal? Also looking for antenna mount ideas, anyone do the front fender/hood like an automobile?
A83EF9C5 757E 4A7F A82B 7FA24B3A230F
Reactions: Chooglin
Chooglin
I mounted my radio antenna right on the door latch. I had to drill a small hole for the mounting bolt. The roll bar protects if from getting wacked with branches.
20180603 210259 20180603 210229
Reactions: Mudder and trigger
Mudder
Mudder
11,348
84,458
After getting side mirrors, repurposed the clamp from OEM rear view mirror bracket. Lucky even the TYT 8600 radio bracket lined up with the 3 OEM clamp holes and bolts. Nice quick clamp removal. 10 minutes and done.
D5C91B1F 4C8A 401A 86E2 A9CC69522090 View attachment 78337 46AA6B4E 0AF6 47F4 B499 F4DCE9A9BCC8 C6D91ECA 4537 4D53 8A0D EBECFCDB75EA
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
Reactions: Mudder
Mudder
Mudder
11,348
84,458
@Ragnar406 , just sent pm conversation with a question.
Reactions: Ragnar406
266,477
Reactions: Mudder and JTW
Mudder
Mudder
11,348
84,458
View attachment 78323 View attachment 78322 Mounted antenna on fender behind headlight. Had a nice protected hollow space created between stock fender and Mudbuster fenders, then drilled hole for easy pass thru to under hood. Guess Silicone is next since rubber washer not used. Receiving fine and liking the easy radio removal. Might be picking the brains of the Radio guys as I go. Wrapped excess coax around perimeter under hood to avoid a tight coil. Thanks for help.
D8911D78 9F07 41E9 9BAB 35459893AF6D
Tramguage1
Tramguage1
Texan
7,143
27,177
Somereset, Texas
Anyone know where I can get an extra ty 8600 mount?
jmcampbell54
292
628
Texas
I mounted my winch remote cable in the same area on the drivers fender. Great space for this application.
