2012 big red running rich
P
pete86
ive got a 2012 big red that seems to be running rich. ive owned it about a month and its got about 3000 miles on it from the previous owner. it smokes black with a touch of gray and smells rich. it mainly does this on hard acceleration after a short idle, then fades a bit. its not white or blue. ive changed the oil, plug, cleaned the air filter and even tried running with the air box open with the filter off in the shop. not sure if the air temp sensor, valves, timing, or ecm could cause it. just figure I cant be the only one that's had this trouble
bigc
bigc
421
welcome to the site pete86 does it have any codes displayed ? you could start with that if it does
P
pete86
thanks. no codes on the display so far. it seems to run ok just smokes more than im used to. ive had several Hondas and never had this trouble
Similar threads
Replies
Views
434
Replies
Views
706
Replies
Views
1K
