2012 Big Red Wont Start-all of a sudden
Manatee
Brought my big red to camp drove it 3-4 miles then parked it. Came back a couple hours later to move and it would not start, seems like good power from the battery and the starter is turning but no ignition. Lights on dash are on when trying to start as well but I think this is normal. Is there a fuel filter that could get clogged up or other simple solution?
63,556
Re: 2011 Big Red Wont Start-all of a sudden
Welcome to the community.
Does it have spark?
Do you here the pump prime?
There is a fuel filter inside the fuel pump. On the Rincon's, there was one year it gave trouble.
Manatee
So I should hear the fuel pump when I turn the key to the on position. Just want to make sure I am looking for the correct noise. If I do not hear the fuel pump prime could this be a fuse or just the fuel pump is bad. I did get a new spark plug and was going to change. What is best way to check for spark? Also do you know the gap for 2011 big red? I will be working on it Friday so want to have as much info as possible.
63,556
Turn the key, but not crank. you should hear the fuel pump prime each time for like a second.
It kinda sounds like this --> https://www.youtube.com/watch?v=UiYapUT_8Js
If not, could be a fuse.
Test spark, Remove the plug and rest it against the engine. Have someone turn the key while you watch for a spark.
Here is how -->https://www.youtube.com/watch?v=CpjkiBDSXe8
Manatee
I was getting the fuel pump prime so I pulled the sparkplug and was getting no spark so I brought it in and guy says there may be a recall on the stator for that model. I will let you know how this ends.
Thanks
63,556
Ya, that could be it. It controls the charging system and the spark timing.
Let us know what they say.
Thanks.
Manatee
The final verdict is the stator coil is bad, the dealer said that this model stator coil was not a recall item but they will pay for the part and the mandatory oil change and I pay for the labor which will be $475. The part would have been another $450. Seems like this has been a problem, this is a lightly used 2012 not 11, I had that wrong.
T
timthetrailman
got a 2012 Big Red with 480 HRS on it; put a new neutral switch in, new plug, new battery and now a new coil. Got power from the motor to the coil but no spark in the plug. Going to try re-attaching the plug cap, what else?
spifyd
spifyd
420
178
newhampshire
the part is 240 from Honda and takes about 2 hours to replace if you stop and have Lunch while your replacing it. FIND A NEW DEALER.
HondaTech
If we get a Big Red in with a cranks but won't start 9/10 its a pulse generator. Like spifyd said it's not that expensive, I think we usually do around $340 otd on one. If you go through the right hand side, remove the mud flap that covers the battery, you can get to everything easy. No bed removal needed, and it doesn't hurt to call Honda. Sometimes they might cover the part or labor, usually the part, because they can get it @ cost.
The reason the dealer wants so much is their "covering" the cost of the part. They ain't "covering" crap, dealers like this make people hate dealers in general. If you do call Honda, mention the screwing your dealer was trying to pull.
W
Wileyolebuck
11
Mississippi
My 2010 Big Red 700 just did this. Cranked every time then yesterday turn key and it just clicked. Battery is good. What was the verdict on the problem.
W
Wileyolebuck
11
Mississippi
Just ordered a starter, read a thread on here on how to install. Hopefully this works. 11 years old I would bet this is the problem
W
Wileyolebuck
11
Mississippi
It was the starter. There is no easy way to replace it either. A few busted knuckles and it's replaced. Magnets inside the starter were in 50 pieces.
Reactions: Mudwing and TripleB
A
Allen71
  1. Big Red
I have a 2010 big red 700 I Serviced it last week the crank and ran fine if you hours then after shutting it off they will not crank I have a spark fuel pump primes and fuses are good I’m out of Guesses any one have some advice
