P500 2015 Honda pioneer
Buckman17
Guys I’m new and don’t really know how the site works. I have a Honda pioneer 2015 never had a problem with it before I was giving it a bath since then the cluster isnt working now a and it want crank just turn over.Please help!
Red500
Red500
5,237
56,800
Greeneville, Tn.
I'm sure someone smart will come along and be able to help you. In the meantime. Did you give it a chance to dry out. Hopefully that's all it needs. You might want to check your connections and make sure there is no water in them.
Welcome to the club from East Tennessee.
Red is the fastest.
Pictures or it didn't happen.
105,366
Welcome from Michigan!
First things first when u join…
Pics Or It Didnt Happen!
of the machine.
You probably got water in the bad places and got it let it dry out. Its a common problem.
There is a search at the top right corner if the page. Most common things have been covered and are In there. Use the thread loom option to dig deeper into the forum.
post up those pics or Barney Fife will be coming after you! ;) 🥳
906UP
906UP
13,014
121,332
da Yoop
Check your fuses & relays, inside the battery box. Most likely have a bad connection on the main fuse or relay.....or it got really wet. Post back if you find the issue.
Farmer
Farmer
2,851
16,389
Southern MO
Welcome to the club! Too bad you're having issues. How long has it been since it got wet? It may be time to start pulling connections and hitting them with an air compressor blow gun.....try it after each plug and you'll know which one to fix before the next washy washy.
Reactions: Red500
906UP
906UP
13,014
121,332
da Yoop
Sounds like the main relay or fuse, it's what powers up the ecm & dash when you turn on the key, without it you get no magic pixies to the coil or injector
Reactions: Farmer
