2015 pioneer 700
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
#1 looks to be a tps i dont see any vac line for an iac
63,619
Yep.. hum... There might be an adjustment in there. I have a throttle body in the shop. I'm going to go look.
Do you think opening it up would help. Its set to fully closed from factory.
63,619
Part 1 would be considered the throttle position sensor
Here it is. This might be what you are talking about then.
141f6ab1a3a66b48bb29bc9f03fccbc6
63,619
Yep... Lernt me somein todayies. lol.
Still not sure I want to mess with it.
What outcome would happen if one was to open it up.
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Loosen the lock nut and turn the bolt in raise your base idle it wont let it drop when u flip the throttle trick is scrap off old paint and use paint marker to remark it so dealer cant say well u messed with settings
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Turn it 1/4 to 1/2 turn till your idle raises a bit ;) and u can buy first round when we go riding bro
Reactions: Hondasxs
63,619
If there was a bar I'd buy everyone a round anyways...
Not sure I'm going to mess with it on mine. It runs fine.
Once you learn its nature it never cuts off on me.
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
You wont harm a thing ull actually probably see an increase an increase in stop to start throttle response
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
U just want to turn it till u hear the idle pick up a hair
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
next time I start to work on it again ill take a look at it. for now it's riding time!
63,619
Is number 11 a sensor? My machine idles way to high or way to low sometimes. You think if I clean number 11 that would fix it? I've been scratching my head over this for awhile!!
@Tflynn
Lost your post with a server upgrade. But I read it..
Yes, This may be the issue. #11 electronically controls the choke.
Reactions: Elkhunter
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Awesome thank you! Ill give that a try and let you all know.
