P500 2015 - what to watch out for and where to look?
L
leboyd
24
39
houston
I've lurked for a while and decided to join today to ask.
I'm considering a 2015 with 400 miles on it. I understand the differences between the pre-17/post 17 models and read the posts about snorkels (as the one I'm considering has one). I've looked at the posts on valuations and think the asking price is in line. I've also watched tons of videos on upgrades, abilities, maintenance, etc.
But what I haven't found is what I should look for and where I should look when I go inspect the one I'm considering.
Can you help me with creating a list (other than what I would consider typical engine and suspension areas)?
Thanks
Reactions: Biteme
L
leboyd
24
39
houston
I think the blue is faster also :) However, this one is red (slowest?) and since I will only be using it on my small ranch for work and hunting.
  • Haha
Reactions: Biteme
O
oldfortyfive
595
1,316
Illinois
Off the top of my head...
  1. Avoid one with a snorkel unless they can prove it hasn't been under water. Long term there will be more problems without perfect maintenance.
  2. Try to get a feel for if the owner was diligent on maintenance
  3. Look for obvious abuse
  4. Check carefully for rust issues
  5. Leaks?
  6. Fluids full?
  7. Tires?
  8. Brakes?
Not much different than shopping for a car of truck.
Reactions: Biteme and trigger
L
leboyd
24
39
houston
Thanks. I guess there's not any you-better-check-this-because-a-lot-of-them-have-this-failure issue. That's a pretty good reputation.
Since I'm on my 4th Goldwing with never a mechanical issue, I'm comfortable with Honda.
Just glad to hear there's not any known gotchas.
Reactions: Biteme and 500oneer
NTCPrezJB
NTCPrezJB
President of #NTC
101,345
905,249
Canton, OH
Might give the front a arm mounts a close look. They are a weak point so they could be bent if it was abused. (They are generally only welded on one side from the factory.)
The rear 1 1/2” hitch receiver can get bent via upwards pressure so I’d take a look at that as well.
Battery cover bolts have caused people grief. I’d open it. Might show nothing but factory or could show a sign of a half ass fix that would make one wonder how they really took care of the machine.
Typical check the air filter/oil situation of course.
Snorkel and stock or AT tires would not bother me much but snorkel and v/tractor or obvious mud tread tires would make me think twice. Overall snorkel look might indicate how they maintained the machine. If it is cobbled together maybe they suck at DIY but think they’re a shade tree mechanic.
L
leboyd
24
39
houston
Thanks for the pointers.
When someone puts a snorkel on do the generally do anything with the location, orientation, etc. of the air filter, or just come in from above?
Reactions: Biteme
NTCPrezJB
NTCPrezJB
President of #NTC
101,345
905,249
Canton, OH
I'd say most try to make it blend in with the machine. On the P500 it is pretty easy to have it sort of follow along the cage up to around the roof line and have it all painted black (or color matched to the plastics) to have it look like it belongs there. An all PVC setup with a fernco (or similar) adapter to a nicely cut stock intake tube wouldn't make we wonder.
If it is still white PVC and generally looks slapped together (RTV looking like it threw up around the airbox lid or something) then it would indicate to me they don't give a s*** at all. In that case, I'd guess they haven't bothered to do the break in oil change either. Just one man's opinion though for whatever it is worth.
Edit ... Air filter in the stock location or moved to the top of the intake in open air .... neither would overly concern me, but there is a vent from the motor to the stock location. I'm leaving mine in the stock location because of that. A prefilter on the snorkel intake is always a bonus though even if it is something as simple as a piece of pantyhose to keep big chunks of dirt and bugs out while not restricting the airflow.
157,872
Yeah, having a snorkel wouldn't freak me out either. I think they should all be snorkeled for the what if's. Ask about the first service and what was used. It only has 400 miles so it isn't even ready for the second yet. Condition of the air filter will probably tell the story. If it's brand new, that might throw up a red flag too. Like Old 45 said, get a feel from the owner, if I get a bad vibe I'll walk regardless of the price.
L
leboyd
24
39
houston
Just got back from looking at it. The snorkel is a good one and well installed, not DIY. The oil and coolant were clean, as well as the air filter. Everything looked in good condition - all cv joint boots were good and no bent a-arm linkages.
What range of pricing should I consider as "fair"?
Does anyone know what is required in Texas to change ownership?
500oneer
500oneer
15,000 mile club
419
1,044
Central PA
Trade in value is $4,400 and retail is $6,400 at the dealer. You didnt say what other options it had beside snorkel. Honda roof and windshield are pricey.
Reactions: Biteme
L
leboyd
24
39
houston
We agreed to $5,400, which I think is a fair price for both of us. I pick it up Thursday and will take it to the ranch on Friday. Looking forward to tooling around on it and learning more about it.
Thanks for the input folks.
500oneer
500oneer
15,000 mile club
419
1,044
Central PA
Good price! I think almost everyone here on this forum has at least $10,000 in thier machines.
Todd627
Todd627
56,390
616,003
MI
@leboyd don’t forget to post some pics whne you pick it up 👍🏼
And, Congrats🤘🏼
L
leboyd
24
39
houston
I hesitate to say I can't see spending $4,600 more on it. I looked up the front locking diff everyone talks about, but they are out of stock and it's $460, not $4,600 :)
I have a 3,500 winch I've got saved in my Amazon wish list and I'll probably look into a fold down windshield.
But other than those items, right now I don't know enough about them :)
And if I did spend $10,000 on it, that's $3k-5k less than a new one with all the add ons :)
NTCPrezJB
NTCPrezJB
President of #NTC
101,345
905,249
Canton, OH
🤔We can help get you to 10k. ;)
TriggerShield from @trigger
box from box @Choogsbro brother
Skid plate
Winch
Roof
Locker
Power steering
Elka or Walker Evans shocks
Moose 2" receiver
Custom graphics from creativeutvgraphics.com
Switch plate from @Hondasxs
Lighted whips
Cube lights
Light bar
Dual battery setup
Aftermarket tires and rims
34,174
Lmao, famous last words. Have a quick conversation with trigger about this....🤣
Mods and accessories are fun and addictive, just don’t keep a tally....👍
Reactions: trigger and futzin
L
leboyd
24
39
houston
Also, I want a stronger battery. Looking at the Yuasa GYZ. Anyone have good or bad experience with these? The one I'm looking at has 500CCA.
(Not ready to go dual yet because I don't have the time right now. I will be doing that probably in August)
