2016 Honda pioneer 1000-5. Won’t go into gear
Bradmc87
Bradmc87
24
34
Conehatta, Mississippi
So I’ve been having problems with my 1000-5 going into gear. Using the gear selector has been getting worse. I got stuck in the woods it wouldn’t shift into any gears using the gear selector handle, the cable is super tight and I had to manually knock it into gear by the transmission to get into gear? Any help would be appreciated. This pic attached is where I have to shift it. Super hard to go into gear
DRZRon1
DRZRon1
852
2,744
PA
need more info, and of course I learned pictures of the machine.....
how many miles?
how much maintenance has been done to cables, cable adjustment over time?
how much mud and water does the machine see?
you been inside cable adjustment box lately?
did you inspect linkage\cable end to end for damage/kinks, has the shift mechanism been apart at some point?
my first guess would be pb blaster/wd-40 will be your best friend
lee
lee
Village Idiot
2,338
13,122
Springfield Ohio
Probably NOT the junction box (fluxcpaciter).
Need to figure out if it's the cable or the shift lever.
Unhook both ends of the cable and see if the culprit is obvious.
The shift lever has several pivots that will want re-greased after 6 years.
If the cable is the problem replace it. (It looks like the cable boot is torn in the picture)
Bradmc87
Bradmc87
24
34
Reactions: Buggyman
Bradmc87
Bradmc87
24
34
After a little bit of digging turns out it’s the shift cable had broken right under the rubber boot in the picture. And yes I had adjusted the cable a few months prior. Hopefully a $34-40 cable will do the trick. I took the cable off and I am ordering another one. I will post pictures tomorrow where the cable was broken for future reference’s
HondaTech
I've seen this a couple of times. The plastic sleeve breaks and allows the cable to flex instead of push.
Bradmc87
Bradmc87
24
34
My shift cable came in today. Does anyone have any advice before I dive in the cable replacement? I’ve heard it’s a pain in the ass. Also I’m hoping my gear tumbler or shift forks ain’t broke, read that could be an issue
Bradmc87
Bradmc87
24
34
Got it on fella’s it was sort of a pain in the ass doing it alone routing the cable and adjusting the gears correctly. I haven’t seen low in a while. That been said, it feels like when I’m applying the brake it isn’t helping with the gears change. Any ideas? Air in the lines?
BTW 2016 Honda pioneer 1000-5 deluxe. 8400 miles
