P500 2017 500 tic, did lash, manual plz
P
pioneergotictic
42
53
canada
Posted a video, 2017 500. Set lash to .15mm and .25 exh, still terrible rattle tic, I read Cam something with decomp springs, maybe oil pump, Conrod wear, looking for a service manual to see what I’m getting myself into
5,028
22,469
Posted a video, 2017 500. Set lash to .15mm and .25 exh, still terrible rattle tic, I hear Cam something with decomp springs, maybe oil pump, Conrod wear, looking for a service manual to see what I’m getting myself into
In the upper right of your screen, click on your avatar, then click on Account Upgrades. Sign up, get free PDF manuals here. It's like $15 a year.
P
pioneergotictic
42
53
canada
Service manual is free to members. Don't know how much that is anymore but it's worth it.
@906UP might have some insight?
yea im sure its out there im trying to search this website. thank you kindly
906UP
906UP
13,026
121,452
da Yoop
Yikes.....that's not valve lash!!! You got a rod knocking
  • Wow
Reactions: Jason W and CID
P
pioneergotictic
42
53
canada
thats what i fear its gnarly trying to find a cost effective solution for the customer, first a bath, then what kinda special tools needed or how to fix this, might be 2g in canada here to repair, price out whats wore, jug, oil , pump, cam , head, bearing kit gasket kit i could go on
  • Sad
Reactions: CID
906UP
906UP
13,026
121,452
da Yoop
Sorry bud but you best be pulling the engine, it's not hard, get the manual and go step by step.
Here's a few pics from when I did the 520 cyl conversion.
20201229 183253
20201228 170302
20201211 172719
P
pioneergotictic
42
53
canada
no worries pulling the engine is no big deal i knew that the seconed i heard it after setting the lash. i like your set up!!!any special case splitters needed? if its big end con rod wear easier to buy a complete AFTMARK bottom end or
906UP
906UP
13,026
121,452
da Yoop
You'll need a couple pullers to the the flywheel & clutch basket off, I bought them off Amazon.
Reactions: CID
P
pioneergotictic
42
53
canada
Ah ok until I read and see what I got for tools we will see. Amazon no kidding!! Just search 500 honda or is it like a generic type puller, again I’ll just apply for the manual and read thanks tho appreciate it, stay tuned
906UP
906UP
13,026
121,452
da Yoop
Messed up jug piston and con rod got hot, not good
Any clues as to why or how? Dirt in intake? Submerged? Etc...... These are pretty reliable engines overall.
Reactions: Mudder
P
pioneergotictic
42
53
canada
I’ll have to pop the air box and check it out. Not to sure. The sides of the cylinder show areas of cross hatch parallel to the wrist pin. The areas with nasty transfer are perpendicular to the pin, dont know if that means anything piston slap or how the piston was interacting with the jug. Today I’m gunna take the engine out and look further for more failure and build a parts list, I got a service manual from the membership here
P
pioneergotictic
42
53
canada
I guess lack of maintenance, oil is black maby ingestion. Excess heat? Rod is blue. Rotates still but it got hot enough to transfer
Reactions: Mudder
5,028
22,469
I guess lack of maintenance, oil is black maybe ingestion. Excess heat? Rod is blue. Rotates still but it got hot enough to transfer.
Unless the air filter is missing, that damage looks like it was run without oil. Maybe a bad oil pump?
Reactions: Mudder and 906UP
906UP
906UP
13,026
121,452
da Yoop
Screenshot 20240202 090203 Gallery
Some of that bluing is normal from inductive heat treating the crank pin area & rod. This is from my P5 when I did the 520 cyl mod.
