2019 1000R front right shock clunking noise
Vondy
Vondy
1,400
8,963
Houston,OH
  1. Talon X4
Re torque your a arms. I had what it thought was shock clunking and ended up being a loose bolt in a arm. Felt tight even when jacked up. Worth a shot anyway.
IDIOT
IDIOT
279
752
Kingman, Az.
I run Shock Therapy limit straps on mine and I just installed a pair on my buddys Talon yesterday. You will only need the fronts but make sure they have a clevis and are adjustable such as the Shock Therapy brand.
107,323
What's causing the front shock clunking noise. It seems to be when shock extends after compressing.
Was gonna suggest limit straps but the masses have you covered. Should have them anyway.
BTW, no pics of u rig yet. Congrats on your first post since joining almost 4yrs ago! You should know the drill by now! ;)
Pics Or It Didnt Happen!
5,048
22,628
Yep, another ST limit strap user here, fixed me rite up. They’re proud of them $$$ but worth it to me. Iffn yer frugal, there are other LS available but less adjustable than the ST setup. Pics are hard for me to post from out here in the desert so I can’t show how pritty they are. 😍
DRZRon1
DRZRon1
865
2,807
PA
you can get a set - 2 limit straps with the adjustable clevises from PRP for $150 if you are on a budget, even more budget friendly is to bag the adjustable clevises and keep an eye on the stretch of the straps and just replace the straps as needed - straps are cheap
