P1000m5 2019 HP1K5 overheat issue
FL_CrackerLife
FL_CrackerLife
182
824
Lecanto, FL
I never really had a problem with my buggy overheating, mostly because we don’t ride long distances, but after the ‘23 TO, and a more recent ride locally, it’s got me thinking.
After the ‘23 TO I installed a Radiator Fan override switch hoping it would help and it hasn’t, now I can just have the fan running non stop, but she still runs 3 bars and eventually 4 bars with the red light on the dash. While on our way back to camp, I removed the bumper bash plate, and hood to allow more airflow to sufficiently cool it down, it helped a little, but it was still at 3 bars on the temp gauge. I with help, flushed the radiator cooling fins from behind with a radiator cleaner nozzle. it seemed to have helped a little bit, but still runs hot. My next few steps are to flush the coolant, refill, burp and bleed the cooling system.
I wound up creating some airflow holes in my Slasher bumper bash plate, hoping it'd help, I also plan to cut out where it says slasher allowing for more airflow and also to make it easier to spray the radiator fins.
Any thoughts, or recommendations are appreciated. B4309b57c3bca4ea64483cee49d7850a
. 92b571536e8bc9d0b90e52aa0ac5793b
Sent from iPhone using Tapatalk
63,988
What year is yours?
My similar setup has been through it all, I have never overheated and even have the "slasher" covered on mine.
Have you done the steep incline burp?
Run it up a hill or winch the front up very high and let it idle for a bit. Leave the radiator cap on as it needs pressure to not boil over at temp.
I still find it odd that some will overheat quickly while others are fine.
107,308
Do it from front and rear with a power washer preferably hot water.
Side note, on some older threads there were folks over heating. Turned out to be that bumper and winch, not getting enough air flow especially once u get mud/muck in there. Just for $hits and giggles, Take it off and wash the radiator real good then dive it and see what happens.
DRZRon1
DRZRon1
865
2,805
PA
what he said above....
also - I would take the garden hose, a few beers and stand there and clean the fins front and back until the water runs clear, then do it again for another hour
what is behind the radiator under the hood? - you need to move air across the radiator - its just a heat exchanger - how much mud is caked around the coolant lines that run to the back of the machine
if every little bit helps you are answering your own question
next step is id take the thing on the front that seems like an overly complicated heavy winch mounting plate off 🤟 :cool:
FL_CrackerLife
FL_CrackerLife
182
824
Lecanto, FL
What year is yours?
It’s a 2019. I have not done the steep incline burp yet.
FL_CrackerLife
FL_CrackerLife
182
824
Lecanto, FL
As far as I know; stock components behind the radiator/under the hood. It’s pretty clean, just dust mostly. I deep clean after every wet ride with purple degreaser and a 1500psi pressure washer. Should I use a cleaner on the radiator itself? The coolant lines appear to be clean from the radiator to the firewall (front footwell steering console area) I haven’t dropped my skid plate yet, but the last time I had it off, it was fairly clean.
NTCPrezJB
NTCPrezJB
President of #NTC
101,502
906,832
Canton, OH
I think this is ultimately going to resolve your issue. Trapped air will definitely cause coolant system issues. If you’ve added water due to boil overs you should check the remaining fluids temp rating. I can’t think of the proper name of the tool but every auto parts store I’ve been in sells them. You might want to flush and fill the system if it is way off.
FL_CrackerLife
FL_CrackerLife
182
824
Lecanto, FL
I just picked up a Radiator Genie spray wand set off the tool truck, I’m going to re-flush out the radiator, clean all the cooling hoses, and burp the tank.
I haven’t added any other fluids to the radiator or overflow bottle, but last time it got hot, the overflow bottle was 1” over the high mark.
Anytime the buggy would get to 4 bars, I’d use a water bottle and some cooler water to spray onto the radiator to cool the buggy down while it was still running.
My next long ride is new years weekend. We’re gonna ride the sugar sand trails of the Ocala National Forest in central Florida. That should work the buggy enough for me to really test the cooling system, and see if it’s fixed.
Reactions: ChadD and NTCPrezJB
Mopower58
Mopower58
CST is the Best!
70,970
650,264
Crystal Springs,Ms.
I just drained my coolant by removing the two plugs in the lower metal coolant hoses. Used an automotive vacuum assisted adder. Refilled with Honda 50/50 coolant, ran it, let it sit overnight and topped it off. Loaded it up and took it to TO 2022. Never been over two bars and it gets hot in Mississippi.
107,308
Yes. Commercial foaming coil cleaner. or the best degreaser u can get. Spray the F out out it on all areas you can get to and let it set on There for an hr. Then pressure wash it preferably with hot water.
Your issue is not flushing the inners. You've done that. And if it was that, you would have other problems than over heat. You got to burp it tho. Do all that, check it then remove that winch bumper and check it then report back. Work smarter not harder.
Bighat
Bighat
875
3,739
Gallipolis Ohio
Two more cents. How long does in take to overheat? If it over heats in like ten minutes or less then I say you need to burp it. As far as cleaning, I would never use a pressure washer on a radiator. You can damage the fins. Coil cleaner works good. I was alway tought to spray the water hose from the back side of the radiator. I also spray the front but only after I get most of the crap out from spraying from the back side.
FL_CrackerLife
FL_CrackerLife
182
824
Lecanto, FL
It takes about 30-45 minutes of steady driving. The last time it overheated I was driving in sugar sand, I had the buggy in 4wd for better traction, and carry some extra weight in the back. (Spare tire, cooler, toolbox, and kids)
107,308
Take that bumper and winch off and try it. Get it more air. I know your hating the idea and your fishing. But Ive seen this more than once with that set up, and one time in person. Just do it and check it off your list. For your sake, I hope Im wrong!
So says you! 🤣
Being an HVAC tech, fo sho not on those fins cuz they are soft aluminum. Auto and sxs fins are much more firm ridged (NoHmo) kind cuz of the debris, heavy rain, snow, rocks and hail @60-80+ mph. That being said, I wouldnt stand there 2” away for 15min in one spot. I would think @FL_CrackerLife has enough sense not to do that? Lol. Ive use one on both my P1K5 and Talon countless times to get that crap out of the nick and crannies you can’t see. Run into this $hit on AC’s every summer. Looks good form my Yard! Then they have issues, then we separate the 2 sections and well…… customers says! I didnt know that cottonwood could pack itself in there like that? The outside washing i did looked ok to me!
$95 service fee sir! Thank you very much! 🤣
FL_CrackerLife
FL_CrackerLife
182
824
Lecanto, FL
I didn’t plan on using a pressure washer to clean it out. I have decent water pressure at home, and compressed air. I really don’t want to have to remove the radiator, but time will tell.
Do y’all think it could be an over weight issue that is making the buggy over work itself?
  • Haha
Reactions: ChadD and Remington
107,308
Knowbody said to remove the radiator! :eek:
Nope, weight wont have anything to do with it unless your over the recommended limit, going uphill hundred plus degree heat.
Your fishin! Lol
Im out
Reactions: ChadD
FL_CrackerLife
FL_CrackerLife
182
824
Lecanto, FL
I was trying to get away from disconnecting the wires I have in the bumper, I have some rock lights, side lights and my winch remote wired into it. But, that can all be disconnected or cut. Haha.
IMG 7362
Reactions: ChadD
FL_CrackerLife
FL_CrackerLife
182
824
Lecanto, FL
Your fishin! Lol
Im out
Not sure what you mean by fishin? I haven’t had an opportunity to work on y’all’s suggestions yet, but hopefully with some pto during the holiday I can get some work done on it and report back. And living in FL the heat can be up there.
Reactions: Remington
107,308
By fishin, i mean looking for more options than doing the simple things first.
Ive said this many times on threads. Like I tell my apprentices, dont go in to a no heat or no cool thinking its the most difficult complex thing causing your problem before you check off all the “easy stupid couldnt possibly be” stuff or you will kick yourself in the ass when u waisted all that time just to find out it was a simple 15-30 min job thats commonly overlooked.
toddvdh
toddvdh
1,072
7,063
Green Bay, WI
I would take the radiator right out and clean it. Then burp it after reinstalling. I had to do that yearly on machines with winches and bumpers in front of the radiator.
Another way would be a-arms, portals, and at least 36” tires. Get above the dirt clogging your radiator
TripleB
TripleB
11,932
101,253
Caryville, Tennessee
Have you ever had the coolant boil out of the reservoir or have you ever had an overheating issue prior to this? If the answer is no, 100 bucks says it's mud you can't see inside the fins. I ran that same bumper for years, and I'm always riding with a heavy load lol. Every single time that my machine was starting to run above 2 bars, it was mud in the radiator. You have to have clean water going through the fins when washing it out or its not actually clean. The only time I had to burp mine was after my first overheating issue due to the fan not coming on and it boiled out coolant.
Reactions: toddvdh
