2019 talon issue
Banksy45
Florida
im new to the forum and was curious if anyone had this problem and if so how to fix? ive tried cleaning the grounds, checking the battery terminals, i triple checked to make sure there was enough oil in both the trans and engine, and a couple other things that the owners manual said to try but all has not helped this issue. it happens at random times from what i can tell and when it does happen i cant drive the vehicle or even shift it into a gear without it dying. any suggestions would be appreciated.
SLOWPOKE693
SLOWPOKE693
1,641
6,279
Somewhere in Texas
Looks like its telling you to do a clutch relearn. Do you have a PV3 tuner? The relearn procedure can be done using the PV3 in diagnostic mode.
PaulF
PaulF
1,462
4,810
Don't need any tuners to do the relearn. Factory Procedure attached...
  • Clutch Relearn Process.pdf
107,323
Its flashing a code, but the video ends before it loops around again.
Dont you just love that?
I have customers that do that all the time. “But thats what it does” yeah but its not enough for me to figure out whats happening 🤨 😂
5,048
22,628
Photo tip - don't shoot vertical video, EVER. o_O
Banksy45
Florida
The MT/AT is flashing because whatever issue is present.
Make a longer video so the code flashes atleast twice.
I’ll try if I can get it to do it again, but it just flashes the same 2 long and 4 short dashes
PaulF
PaulF
1,462
4,810
That is DTC 24-1 of the DCT. It is as follows..
1641350562317
I have attached the pages from the service manual to diagnose the code (starts about 2/3 down the first page)...
  • DTC 24-1.pdf
rsbertsch
rsbertsch
Fort Mohave, AZ
  1. Talon X4 LV
Do you have a 2-way radio installed? If so, where is your antenna mounted? Is the antenna a ground plane or a non-ground plane type?
I had the same problem as you are describing that is the reason for the above questions. I purchased a Rugged 60 watt 2-way radio kit with antenna. I had a shop install the radio and antenna, however, they did not know s*** about how a 2-way radio works. The type and placement of the antenna is the most critical part of the radio system. 60 watts of Radio Frequency (RF) radiation can do a lot of things like give the radio a great deal of range in talk power and cause havoc with other electronics in your Talon.
In my case the antenna supplied with the kit was a ground plane antenna. A ground plane antenna needs to be mounted on a flat metal surface that is in turn grounded to the chassis frame work. The shop mounted it on the rear roll-cage with a bracket and a ground wire attached to a screw drilled into the cage. This caused a huge problem for the Electronics in the Talon.
The Talon dealer could not figure out why my talon would quite running while driving. The dash panel would act up with all kinds of warnings, some flashing - some not. I could restart the engine put it in gear and it would instantly stall. If I left the Talon alone for at least two minutes with the ignition switch turned off it may restart and allow the electrical system to reset and let me put it in gear and drive away, at least for a few miles and then it would do it all over again.
The cure was to move the Ground Plane antenna to the center of the plastic roof and place an eight inch round piece of metal on the antenna base and then run a ground wire to the top bar of the roll cage. My electronic problem disappeared completely. Turns out the RF interference was being radiated into the Talon’s computer and was causing it to go nuts.
34,174
Wow, that’s crazy…..
