2020 Talon 1000X-4 FL - Lower Door Bags and Other Bag Options
Steve-O-Utah
Steve-O-Utah
30
59
Can find lower door bags for the front doors of my 4 seat Talon. Do you know if anyone makes them for the back doors?
  • 0SL58-HL6-A00 - Honda OEM Front Pair
  • B0113-05001BK - Kemimoto Front Pair (Anyone have experience with these?)
Also found the following. Does anyone have experience with any/all of them?
  • B09RGWRVJG - Kemimoto Overhead Bags
  • B083S5FXX4- Kemimoto Rear Center Bag
  • 0SL58-HL6-A00 - Honda OEM Corner Storage Bags
As always, Thanks for any help.
Josh97stang
Josh97stang
106
539
Sheridan, AR
I have both the B0113-05001BK - Kemimoto Front Pair and B083S5FXX4- Kemimoto Rear Center Bag. I did not like the center bag in its designed position so I moved it up a bit higher. I have a rear camera so I was not worried about blocking my view. I have not had any problems with either bags and have had them for a little over a year now. I will attach a picture of the center bag mounted in the Talon. It’s not a really good picture but it’s the only picture I have of it.
0BCB96AF 25F1 49C3 B847 8EB00D3939AB
Steve-O-Utah
Steve-O-Utah
30
59
I have both the B0113-05001BK - Kemimoto Front Pair and B083S5FXX4- Kemimoto Rear Center Bag. I did not like the center bag in its designed position so I moved it up a bit higher. I have a rear camera so I was not worried about blocking my view. I have not had any problems with either bags and have had them for a little over a year now. I will attach a picture of the center bag mounted in the Talon. It’s not a really good picture but it’s the only picture I have of it. View attachment 344513
Thanks for the info. Highly considering both.
107,985
I have the Kemimoto for the front doors, there nice. If u have the Honda lower doors the hardware provided does the trick. If u have the tusk lower doors like I have you will need to modify for mounting. Wasn't bad, works well
