2021 Live valve named “Icebreaker”
CrosbyTalon
CrosbyTalon
59
117
Minnesota
Picked this up in Missouri on September 26th and brought it home on 27th.
So far not a ton done but here is the list.
-SuperATV flip windshield
-Honda rear window
-Heated seats
-Rough country winch and mount
-Air intake mod piped into cab with spectre filter (UPDATE...fine for low speed and trail riding but too much cab noise on highway cruise above 50MPH, going to route it back outside the cab)
-Backup camera and screen
-Rugged Air Intercom system
-KFI plow and mount with hydro turn
-Spike lower door inserts
-SuperATV hitch plate
-Kemimoto wheel well and firewall mud guards
-Light Bar
-Gauge Relocate
1EC999D3 0A30 4CD2 985C F1195A8F0493 C3B56011 2EFE 46E5 A2B5 9F15E521B727 13E985B6 77D8 4FF2 BA6D 61A520844941 049B01EF B651 4C8E A993 3A4CD4FE523D CC8F5BFC A5E7 405F BAFD AA0CAC9C1584 85212B8C 71CA 48DE 80CE 2B5834E5FA86 044AE64D 5C63 4829 8AB4 CA24B95B01D7 D4C27A85 6FFF 47B1 8813 E84CD75FF5E4 128E0E9D 95FA 4506 A80C A0C8733E1447 032D8848 CED4 4855 A222 11C204E25C45 B3470A4F CCB9 4776 AC7E FA2AFC31A57D 29C5C75F 3EBD 455C 8B55 718E6A9F4613 D3499724 A744 45BA 802A 99F05851D08E BD94686C 717E 44C6 8AAA BD5E60A1D705 4CA88926 126B 450E 81BC CE782A9E82BE 3FEB5F91 753C 4E3E A11B AF5376783B46 949847DE 0EB1 4B15 A6D6 CA7C7F058E57
207,989
-Honda rear window
-Heated seats
View attachment 232108 View attachment 232109 View attachment 232110 View attachment 232111 View attachment 232112 View attachment 232113 View attachment 232114 View attachment 232115 View attachment 232116 View attachment 232117 View attachment 232118 View attachment 232119 View attachment 232120 View attachment 232121 View attachment 232122 View attachment 232123 View attachment 232124
You have been busy! Looks good!
CrosbyTalon
CrosbyTalon
59
117
Minnesota
Just ordered Dragonfire EVO belts, 44" lightbar, and some acoustic butyl rubber backer for noise control between engine and cab. Will post updates as things come along. Patiently waiting for PaulF to get in touch with me regarding the gauge relocate so I can mount switches. Don't want to cut a bunch of holes if they will be moving for the Gauge relocate....
CrosbyTalon
CrosbyTalon
59
117
Minnesota
Ok. Looking for help on mounting fuse panel and running wires. Anyone have recommendations for locations? I wanted to place by factory fuse panel but there is not enough room. Only place I can find is on top of glove box but that means screws penetrating into glove box. SOOOO...suggestions are appreciated!!
ToolTime
ToolTime
38
99
Oregon
I’m in the middle of installing the SwitchPro 9100 as other have on here, have to say the more time I send with it, the more I like it. Mounted it to the left of the air box as high as it will go. Right near the battery, not for from the OEM fuse box, I think it is a good location for SwitchPro or other methods. Remove the plastic as you would to access the air filter box and you’re in.
CrosbyTalon
CrosbyTalon
59
117
Minnesota
I assume I am looking at the correct one but wholly schmoly! $680 for a switch panel!!!
sspeederr
sspeederr
391
661
I mounted mine under hood behind the rubber flap so it’s out of direct water and easy access also that is the common location for the second battery to be installed so ease of connection for switch panel and accessories I’ll upload a pic in a bit it’s a lil mess atm I am still configuring the wires
Reactions: ProudDadOf5 and CID
ToolTime
ToolTime
38
99
Oregon
$549 at most retailers so yes, not cheap. Totally enclosed solid state means I shouldn’t have to mess with it ever again once its done. Having the ability to “tune” the outputs to certain amp limits, color, brightness, tied to inputs (think when high beam comes on light bar lights up or dash panel dims when you turn the lights on), being able to remote control the lights from your phone, I’m going to experiment with remote start, the thing is just nearly limitless in its abilities. I have run a few of the switched circuits up front to a terminal strip, and will have the same in the back so I don’t have to go through the center console again in the future. Super clean install and flexibility are what I am liking best, no rats nest of wires/fuses/relays.
5,052
22,658
White is so fast, it can't keep color on! Last several trips into the dealer ship, they ask me how Rooster is doing, my wife named it that and that got Walter with Creative Graphics involved, he came up with some kick ass graphics, John Wayne style, Rooster with the movie intro fonts. Walter made an impression. Guess I need to post some pictures?
I considered the Mongrels but they were on backorder until October (from August). Aren't they 10 plies? - curious about the ride quality. What tire pressure are you going to run? That tread pattern looks similar to the 30" STI Chicane RX eight ply I ended up with.
Anyone know a good decal guy that could make a nice decal that says Ice Breaker in Silver/Blue to match the decals of the Talon?
I'm interested in getting my avatar as a large hood decal.
207,989
I considered the Mongrels but they were on backorder until October (from August). Aren't they 10 plies? - curious about the ride quality. What tire pressure are you going to run? That tread pattern looks similar to the 30" STI Chicane RX six ply I ended up with.
Creative Graphics, he's on the vender list
CrosbyTalon
CrosbyTalon
59
117
Minnesota
You can get the mongrels in 10 or 8 ply. Mine are 8 ply and I am at 16PSI rear and 18 PSI front for now, we will see how it goes. I ride a lot of tar too and from the trails so a DOT tire with less howl and better wearing was important for me. I got a killer deal on these off craigslist and figured I would give them a shot.
SpeedBuggy
SpeedBuggy
1,289
10,214
WA
I ran the Terra master 10 plys. Same brand as the mongrels. They were great and tough. Probably a better desert and hard pack tire. Currently running carnivores and the difference in sidewall stiffness is noticeable. I ran the TM at 12 psi and the carnies are at 14 but they feel softer. My only worry is the sidewalls.
ProudDadOf5
ProudDadOf5
3,113
24,132
Winfield, WV
  2. Other Brand
@jrplaza2008 (Creative Graphics) will hook you up.. He did my custom graphics and I think they look awesome!! I need to get him to redo my hood graphic.. ✌🏼PDO5
Reactions: Plumber32
CrosbyTalon
CrosbyTalon
59
117
Minnesota
Update. Got passenger seat sound mat installed, harnesses in, and light bar mounted. FYI dragonfire EVO belts do NOT work in the Honda 2 seat. Sent those back and went with 4.2 PRP and the quality is much better than Dragonfire. The buckles tighten up and loosen up WAY easier than last set. Now its my turn for gauge relocate kit just in time as I am wiring everything up! Thanks Paul!
5A44EA73 4384 4AF1 B926 8F5D4781E0C7 F4439943 5E0B 46FA A654 AEF09B2F0FC9 26DCCC55 6FEC 4500 97D8 696BAABA5CD5 7ED03222 E35E 4D65 8ABD 4F66738EBFCB
