2021 No Belt Mafia live valve build
sspeederr
sspeederr
391
661
Well I am a lil late to the party for posting a mod for mod build update but here we go. I purchased my 2021 lv back in May and have loved every min of it started off trying to cover essentials and came to realize real quick everything is essential at some point. Here's a list
Honda accessories:
• front and rear a-arm and trailing arm guards
• switch panel, wire harness and sub harness
• rear cab panel
• nerf bars
• front and rear steel bumpers
• rear view mirror
• lower door panels
Aftermarket accessories:
•Satv seat belt bypass
• Dragonfire 3in 5p harnesses
•Kfi 4500lb winch and mount
• Emp shift gate
• Prp rear truss bags
• Rotex gas and storage box
• Gorilla whips and rock lights
• 41in light bar and 2 sets of pods
• Tractor supply storage box
•Satv bed extention
•Ram mount for 10in Samsung tab e for GPS, mapping and music
• Memphis, Sony, rockford audio with my custom enclosure
• Sedona rock-a-billy in 32s
• Nemours switchs for controls
• secondary battery
• Uni pre filter
•36in high lift jack
•Utvma bump seat
Recently added
-Honda glass windshield
-System 3 beadlocks 15in 6/1 offset
-32x10x15 Sedona rock-a-billy tires
-Honda sxs store reverse trigger harness
-Honda door bags
-Honda roof corner bags
-TYT th8600 ham radio
-EMP 41in light bar mount for windshield
hope you all enjoy the eye candy as much as we have thus far
20200911 202929
Resized 20200512 184304
20200512 214012
20200530 231709
20200608 171924
20200610 204045
20200519 220113
20200521 224147
20200526 193713
20200521 224221
IMG 0521
20200831 163650
20201020 182624
20200730 175349
20200809 170216
20200911 202929
Todd627
Todd627
56,446
616,512
MI
Welcome from The Great Lakes State :cool:
Good looking rig and lots of cool mods 👍 Need to add a turbo so you can keep up with the red Talons 😜
#NTC
sspeederr
sspeederr
391
661
#NTC
Ya I have a lot to go im not sure if turbo is the way I wanna go or do pistons head and cams
5,052
22,655
Nice unit! 👍
How did you pick up a 2021 in May? 🤔 My 2021 R just got here two weeks ago.
Reactions: Mudwing and Biteme
sspeederr
sspeederr
391
661
Nice unit! 👍
Your guess is as good as mine but here's proof off my honda finance
20201025 201730
Reactions: SpeedBuggy
sspeederr
sspeederr
391
661
That's just weird, Dude. :eek:
I'm on east coast and this was the first 2021 r we got and have sold 3 since
5,052
22,655
Are you running the Uni prefilter inside the airbox? Check out the link in my sig for HondaBob's snorkel idea. It puts the filter behind the passenger seat where you can actually see when it needs cleaning and if you have a spare, a 10 minute (max) change over. He puts his up under the roof where it's more protected than mine but I don't ride in much rain.
sspeederr
sspeederr
391
661
Mines in box i check after every ride
I have kicked around the idea of snorkle but I don't know if I wanna go that route, I snorkeled my 4wheeler for deep mudding
20190311 201800
5,052
22,655
I have kicked around the idea of snorkle but I don't know if I wanna go that route, I snorkeled my 4wheeler for deep mudding View attachment 231848
I won't normally cut a hole in a body panel (my first SxS btw) but Bob's idea is so good (IMO) and convenient that I went ahead and did it. Now done, I have zero regrets and can only see how it would help resale value (which is really irrelevant at that level). It's just too handy and there are the two o-rings in the stock airbox that have caused others problems. I won't open my airbox but every 2 or 3 thousand miles now that I know how clean the prefilter keeps the stock element. My Talon got stolen (from the dealer no less :oops: ) and I already have the pieces to do another snorkel as soon as I get the new one home. Not trying to dun you into thinking my way, just sharing my thoughts. #beers
sspeederr
sspeederr
391
661
Hey thanks for the insight we tend to ride in all weather types just like u said rain can be factored in and just adding having filter out in those elements im a little un sure off have u had and issues in rain? Cause putting it in cab is out of the question.
5,052
22,655
1. One of my first rides was in several hours of drizzle, I was new and forgot the filter was 'sorta' exposed. :eek: I had no issues. I think it sits in a sweet spot under the roof, especially when moving.
2. You could run it horizontally to the center of the roof behind the ROPS (so not in the cab if you have a back window), there's a spot there between the two slots in the roof that will be dry. I think Bob set HUCK's up that way initially. If you're concerned about intake noise, keeping the stock air intake chamber damps the intake noise pretty well (again, copying Bob's idea). I find the gear noise painful in my Talon and wear ear plugs anyway.
3. There are filter socks designed to keep water out in wet conditions. Or a kid's plastic toy bucket.
4. Come to The Dark Side, we have cookies. :p
PhilCod
PhilCod
337
701
Indiana
After or November 6-8 ride in WV, I plan to snorkel mine like Craig has listed under his "New Talon Owners" link. I live in Indiana, and we ride in the rain often in WV -KY-TN. So my plan is to use a K&N filter on top of the snorkel, and put a 8 quart ice bucket, like you use in a hotel, over the air filter and run bolts and washers through the top to hold it. The K&N has a rubber top, verses the UNI with a all foam design, so it would be easy to bolt to. I am running the UNI in the airbox now. Once I get the snorkel mod done with the ice bucket, I'll post pictures.
sspeederr - welcome to the club. Nice build!!
Reactions: CID and sspeederr
Rottiedog
27
37
Boulder, CO
Honda accessories:
• rear cab panel
• nerf bars
• rear view mirror
• lower door panels
• Emp shift gate
• 38in light bar and 2 sets of pods
•Satv bed extention
• secondary battery
• Uni pre filter
•Utvma bump seat
View attachment 231688View attachment 231673View attachment 231675View attachment 231676View attachment 231677View attachment 231678View attachment 231679View attachment 231680View attachment 231681View attachment 231682View attachment 231683View attachment 231684View attachment 231685View attachment 231686View attachment 231687View attachment 231688
First, what a beauty you have put together!! Bravo. Would you be able to email ([email protected]) me an amended list of yours which will have links and or telephone contact information for the different items you have listed? Thanks in advance for whenever you can do this.
MDFMac
135
240
upstate ny
very nice rig.. but you cant use your cup heater... lol
sspeederr
sspeederr
391
661
Lol I know I know working on that too gotta keep the kido safe first
sspeederr
sspeederr
391
661
Adding further to the build I have been putting it off for some time not wanting to cut up a 100 dollar receiver mount but after a long wait and no company is providing one that will work with factory rear bumper I cut mine up and now with out regrets I have it ready for final clearancing and welding
20201028 203311 20201028 203305 20201028 203259 20201028 202543 20201028 202552 20201028 202416 20201028 202002 20201028 201956 20201027 212625 20201027 205640
