P1000 2022 “Duck Truck”
kandt
kandt
126
762
Bluegrass state
Not so much of a build but adding accessories. I got it for farming and hunting plus for the family to run around on the farm with.
Thought I would mention some of the things I have seen along the way. During the over a year wait I accumulated several things that I wanted to add. Since getting it I have spent way more time adding things than in the seat.
Dealer add ons:
Factory roof
Super ATV flip up windshield
LED headlights
Mid fabric panel
994B8A01 24F6 4154 9253 26F65E9350C2 BB25EEB5 06FF 47F3 A05E 2AF03AB2CE2F 07A9E5E0 3291 408D AC30 5F8B264ACBF9
AF6D176F D79C 42FB 9EAF E092146FC319
kandt
kandt
126
762
Bluegrass state
MudBusters- I love these things. They were pretty straightforward (would have helped to have a second person) during the install…. UNTIL I got to the lower fronts. I don’t have a good pic or it but will try to remember to get some when I go back to fix them.
From what I can tell the 2022 inner front fenders are a little different, or are compared to my buddy’s 2018 LE. The lower part of the front section on the MudBuster instructions were to bolt on using the 4 pilot holes. First on I drilled just as described but figured out I could not access the bolts to add the nuts. I tried everything except taking a ton of things apart. My quick fix was to screw them down with self tappers. I am going back to add nurserts and bolts.
5B0974B8 8D9E 4D90 8CAB 674D1A2C91AC E867C1C5 04D9 4A90 9F16 7B7778BE9366 1F60FFC4 98F0 4ABC 9643 2FC018882D84
kandt
kandt
126
762
Bluegrass state
Siezmick Bed Extender- one of my first purchases during the wait. We knew we needed extra bed space for what we do and having more than three folks at a time ride with gear it was a great purchase. Install was straightforward as well. Only flaw I have ran across is that I bought a bed mat from Rough Country and it is very tight at the tailgate with the extender folded up. A few modifications will fix it.
It will also allow my weed eater to fit inside the bed. Happy with the purchase and it stores up really easy. Good addition for us.
220FC613 4438 4783 AD86 38EE0266BA02 6648CD98 A94D 4D36 8553 591C5A566B22 12ED1411 892F 4098 9C4A F14891277353 7CC6D7CA 4803 4CA4 8F79 7FA84C986261
kandt
kandt
126
762
Bluegrass state
V2 Viper Winch 6000- awesome looking winch. It took some time to get nuts threaded on u-bolts by myself but it got done😤. Would have been much easier with another person to help. Even though I struggled a bit, this thing is awesome. No problems with fit. Looking at the Trail Model, the deluxe did not have the side plates (or mine didn’t 😜) that cover the winch. I had plenty of room, no fit issues. Just as @Hondasxs described in the earlier posts, you have to get the top of the mounting plate under the tab of the frame when installing.
I did not wire it at the time of mounting to the Pioneer. I did all my wiring at one time.
CFFE25FF 79F0 4032 A1DE 9B3D88078D43 D842BA22 BAED 415A 9C1C AF876A16D250 BC2B71F9 EF23 4DA7 B923 1435E8FC2AD2 433BA25D 91B8 47DB 9314 729D7366CB93
kandt
kandt
126
762
Bluegrass state
Forgot to mention. The winch came from the club store with a nice green switch and harness. However, my OCD wanted all switches the same color so I got a premium blue switch and harness from the store.
kandt
kandt
126
762
Bluegrass state
Added electrical stuff-
Mighty max second battery
Tru dual battery kit- club store
Seat belt plug- club store
New key on power supply plug- club store
Cole Hershee relay
Pos/Neg bus bars
50 inch light bar over hood
Side pods
Rear pods
Strip lights to roof for some lights
Ecoxgear 26 in sound bar
Horn
Rock lights
6 in fan under seat
Winch remote and premium switch- club store
Auxbeam 8 gang switch panel
Mounted all accessories and ran wire to front.
Did all wiring at the same time. At times overwhelming and timely. Maybe should have done in steps but wanted to get it all done at once.
NOTE: 3 dead switches on the deluxe model are color coded. For mine the follow switches corresponded to the following colors.
Switch closest to steering wheel- blue/ brown wires
2nd Switch (to right of above)- Puple/yellow
3rd switch (switch next to small switch blanks)- aqua/grey
F6CC200A AB76 4DDC 8509 79416D5B5D4B BC0013AA 4557 4122 A41C AF9E539EEA20 83ABAF98 52D3 482D AF7B 2242935B7FA5 29B13741 8116 40A6 BFE8 020F95EB7DFB BF6FEE95 D896 4CC6 8FF6 84679EEFEB5A
kandt
kandt
126
762
Bluegrass state
The auxbeam is crooked 😂😂😂. Not by design but the hole I drilled for the wire was off a little. I have a cover plate being made for the warning labels and will fix it when they come in.
NOTE: the larger warning label has wires mounted to the back of it. Look at it before cutting the space out. Here is a pic of the backside of mine.
The sound bar is awesome considering the price point compare to others.
Comparing to my buddy’s 2018- under the hood is a little different. Main battery is slanted rather than flat. The back of the fender set has more wiring ran along the frame cross member than earlier versions. There is more plastic behind the fender to help close off the front to the cab area. The rubber flap is not a small area and replaced with more plastic molding. Again this is just my observations from pictures and seeing his machine.
779175AC E239 4FDE 9934 330873CA2827
108,231
Looks good! The original Green Deluxe AKA Sherman is proud.
one thing Id suggest is to remove that warning label THEN install that Auxbeam plate.
kandt
kandt
126
762
Bluegrass state
I have some plates coming in from Crossroad 3D. I will get it fixed once they come in. It was just a quick stick on to see if the wiring was going to work;). It was a turn key 🙏 that it all worked. haha
kandt
kandt
126
762
Bluegrass state
With the three large switches (only rated at 3 amps) I decided to run some smaller items. Rock lights are on one and I split my dome strips one for each of the other switches. Works pretty good for what I wanted.
Seat covers- wasn’t sure they would fit but added the kemimoto seat covers. They fit well. Added rear view and side mirrors before I added most the other stuff. Gotta see what’s behind ya!
I am going to stay pretty much stick for my needs. I enjoy seeing all the different builds and various options, but I think the only plans I have are to get 28s all around by next year and will be pretty much done (I know, yeah right 🤣).
Heat is still an issue with the 2022 model. I haven’t put enough time behind the seat at one time but it feels like it can get hot. I did add the under-seat fan.
DBE9412D 197C 49E5 A186 6D1336F98B10 F7DF02B0 4011 4516 88DC C8D0D8EE0772 482BCE87 FE15 40A6 BB95 6A184F098178 3FD9110E 7E61 49A3 A4C2 44F85C3BC0D0 4EDA5BB6 77C7 406B B497 844E6975D6A1
kandt
kandt
126
762
Bluegrass state
can you take pics of how you did your under seat fan? How did you mount it with those covers?
I currently have it temporarily attached with zipties. working to figure out a framing option, but it is pretty secure. I doubled the ties at each location. It is the black box at upper left corner of pic. Not as many options to mounting as compared with the earlier models. I moved the black rubber coating back to keep if from sliding. There is a small brace bar on the bottom right side of the fan to secure the lower part to keep it from moving in space there.
IMG 6939
kandt
kandt
126
762
Bluegrass state
looks like the bilge fan mod lives on!
My daughter said her favorite seat is the middle of the front seat. She likes the heat🤣🤣
I don't have any experience with other models or side x sides, so the heat may not be as bad as other years. I can feel it rising as we ride and they have not been long trips. If it doesn't get any hotter than it has thus far, it will be good. Time will tell.
GRANITE
GRANITE
People Dying to come see me!
1,100
5,550
Brookville, Indiana
that fan is slick....I'm trying to use the 4" bilge fan and using a strap across the top won't allow the center cover to fit.....We rode 36 miles yesterday and seat got warm but not HOT.....I plan on getting a @trigger shield at TO and hopefully someone can get me a bracket to fit....Thanks for your pics....
bumperm
bumperm
1,852
6,659
Gardnerville, NV
I made this mount on my '21. If you can weld, it could be modified to work with the '22 by adding a spacer between the half-round part (that hose clamps to the cross tube, to drop the fan down further to clear the pan. The bracket mount is easy to remove for servicing, just loosen two hose clamps, and allows positioning of the blower so the intake isn't obstructed.
20211210 212543
kandt
kandt
126
762
Bluegrass state
His shields look like they will do a great job. I am going to see how it goes with the fan and heat. If it doesn't get worse than what we have experienced so far, we will be good. If it gets more intense, I will probably look into a shield from trigger as well. The fan is a 6 inch fan I believe (80 watts). When it runs it sounds like the radiator fan. I have to look at my switch to see if its on or if its the one up front lol. I can try to find the one I got and send it to you if you would like.
