P1000 2022 mirror mount
ODAMO
ODAMO
1,177
3,203
Ohio
Is anyone using the 2022-23 oem rearview mirror mount welded on bracket? How do you like where it places the mirror? It seems way too high to me.
NewHere2
NewHere2
Village Idiot In Training
35,710
303,733
High Plains of SD
I purchased a 8mm - 1.25 metric bolt about 3 1/2” to 4” long ( don’t remember metric length ).
Cut the head off, put a 120 degree bend in the smooth end at about 1 “. Then threaded the bent end with an 8 - 1.25 dye.
Installed it on the bottom of the factory shaft using a metric coupler. Also added a metric nut to each end of the extension to lock the adjustments.
Just the right height now. Gives a great view under the Honda Bag I have mounted behind the front seat.
ODAMO
ODAMO
1,177
3,203
Ohio
I purchased a 8mm - 1.25 metric bolt about 3 1/2” long ( don’t remember metric length ).
Do you have a pic of your custom mount?
NewHere2
NewHere2
35,710
303,733
High Plains of SD
IMG 0819
Hope this helps . I probably should have done a complete build thread on this hack. No actual measurements were taken, I just eyeballed everything.
Safe Riding !
