2022 Pioneer 1000-5 Deluxe factory switches
L
lpd1253
Nebraska
I’m a new owner of a 2022 1000-5 Deluxe with the pre installed switch panel where there are 3 pre wired on/off switches in the control panel. Can anyone tell me how I can connect these to accessories?
NTCPrezJB
NTCPrezJB
President of #NTC
100,937
901,940
Canton, OH
@Hondasxs i believe has something in the club store for that
Reactions: Backwoods
63,710
Not many know how those work, but I do.
There just dead switches. There also not lit.
Blue tape under hood above second battery cubby. There you will find the dead end loops. Cut the white loop into.
One wire is a feed. Other is the switched fed.
Supply 12v or use as a ground switch.
Each has a 3a limit.
Alternatively. We have designed a harness to make them function as most expect. This harness plugs into them converting them to a switch led positive and a ground output to your accessory. Now you can just hook a accessory to it and turn it on.
GovtMule
GovtMule
12,007
116,353
Tennessee
Get the fix from the store. Works flawlessly and it’s easy to install.
Reactions: NTCPrezJB
Red500
Red500
5,268
57,099
Greeneville, Tn.
Welcome to the club from East Tennessee.
