P1000 2022 Pioneer 1000 Trail - wheel centering
E
Espanola_Honda
14
Espanola
I have 2022 1000 trail with 150 km. when i let go of the steering wheel it darts to the right. has anyone else heard of this before. alignment is good. any ideas on what would cause this.
107,301
Are you sure your alignment is good? How did u confirm this?
are you driving on pavement, dirt or trail when this happens? Is it in 2wd, turf or 4wd?
Reactions: Backwoods
The Hunter
The Hunter
68
357
53
Kentucky
Check your tire pressure on all four. If you’re low on one side it will definitely make them pull. I run mine @14psi all the way around but the book says 13 in front and 14 rear, but you suit your self but need to be close all around
ODAMO
ODAMO
1,177
3,206
Ohio
The 2022 book calls for 18 psi on a -3 and 20psi on a -5
If you run on hard surface with rear locker on and your tires are not the same side to side it will pull to the side with lower pressure.
ODAMO
ODAMO
1,177
3,206
Ohio
09ADFBA2 394D 4CB4 BDA3 949BF905D827
Hades187
Hades187
5
11
United States
I guess you can do it without dealer level diagnostics.
I havent had a situation where I've needed to perform this procedure yet.
It may be the answer to my steering.
Since the day I've had it, it never really returned to center very well. Turns very easily no problem there. Just doesn't like to return to zero.
Jankyeye
Jankyeye
563
2,523
Tampa, Fl.
I know this is a bit old but did you ever try this to fix your issue?
