P1000 2022 pioneer deluxe 1000-3 Cryptids
rudyeng
109
554
Florida
Hey guys I wanted to share my build experience. Started out with the factory tires but the Florida everglades bogged it down. I was getting stuck all over the place. I upgraded to the 30x11x14 in the rear and 30x10x14 in the front. That was a mistake. I should have gone with 30x11x14 all around.
The 30x11x14 are actually about an inch smaller and not much wider than the 10" option. That's important because you can adjust the tire size based on tire pressure and remove all rubbing. I've got the tires at 28.5" with very little rubbing at full lock. That's with a 2.5" HL lift. I think I could have reduced the 11" tire pressure further. I'm at 14 psi.
I utilized the factory wheels and did not require fender flares. No wheel spacers. I'm very happy with the final configuration but I have not taken it off road yet. Hopefully it will not rub on the way to deer camp. Hopefully SATV will develop A-arms in the near future.
Pics show pre-post improvements. Stock Vs lift & Cryptids
IMG 20220520 145556866 HDR
IMG 20220629 101928592 HDR
Best of luck !
Rudy
106,079
And you can ditch the bracket lift And fix that geometry on that suspension lol.
Otherwise it looks good.
Pro tip: since this is kinda your build. Start a Build thread and give it a unique name it can also be linked to your avitar. Then you can add to it any new mods.
