2023 Talon X4 lower door
NiwRoC
NiwRoC
Tucson, Az
  1. Talon X4 LV
Currently have a 2023 Talon X4 and I'm in need of the lower door panels. Everyone I've reached out to says the 2023 doesn't match what they currently have in stock.
Thanks in advance.
Scoop
Scoop
4,278
16,035
  3. Talon R LV
You don't have anything UNLESS AND UNTIL we see some pics! POIDH! Rule #4 violation coming in hot!
Welcome from MI.
Thanks in advance.
Assuming you have the 2023 "S" model, without lowers. Any of the ones for a 2019 and up will fit, Honda didn't change anything until the updated 2023 Non "S" models
108,167
Welcome from MI.
He got it on his welcome thread.
Hes good. He kinda slipped it in there
To add my first post. Dont buy the lower doors anymore, (that goes for anybody).
Buy the updated 2023 doors with lower panel that has a pocket and cup holder. The door panel, cup holder are cheaper than the Honda lower doors. The net for the pocket is expensive though, but not a necessity.
108,167
Your saying that the 23’ doors will fit on my 21’?
From everything we've seen yes, I haven't physically taken one off and tried it.
Honda just made the inner panel extend down to where the lower doors panel add on would be. The outer skin attaches the same way and in the same places.
You'll have to buy the cup holder "shell" separately, it's the same as a P1K I believe. You should be able to buy the accessory P1K cup holder kit and get both for cheaper in one hit.
The only thing sorta expensive is the net at $109, the panel I believe is under $80.
108,167
Nice! You wouldnt happen to be able to get some part numbers tomorrow to make it easier to order?
5,092
22,890
Door lowers on a Talon are a sure way to cook yerself like a lobster - dem fookers run HOT in the passenger compartment. I put them on my first Talon (stolen), won't do it again. 🥵 🥵 🥵
108,167
Depends on what area of the US you ride. For example, this past weekend here, it was a bit chilly and rainy. The lower doors helped alot and kept us dry. Kept a decent amount of TN mud out at the TO also. If i need more air from my doors, I have those door latxh thingies that prop them open about 2”
But to each his own I guess
Reactions: Smitty335 and CID
NiwRoC
NiwRoC
Tucson, Az
  1. Talon X4 LV
Mostly will ride in higher elevation desert and I agree it's hot in the cab. Pebbles kicked up and projected into my better half and hit her lip. Suggest a full face shield and got the stink eye. Can you provide the link for the 4 door as well?
5,092
22,890
Rokblokz fender extenders keep the debris out of the cab pretty good but it's wide open out here and I'm not trying to scrape 'em off on trees and trashed out trails. Nor do I have a Mrs. :oops:
I don't remember them being this expensive. 😢
Showing how clean they keep the doors and how clean they DON'T keep the windshield. :eek:
I cr95tCk X2
Honda makes them now, someone on here said they offered better coverage then the aftermarket options.
I cant remember his name, it's the fella with the white Talon painted like an old ATC
Edit: @TerryH Is the member who put the Honda fender extensions on.
RVaholic
Tucson, Az
  1. Looking to buy
  3. Talon X4 LV
I want to thank everyone for their input on this. I'm going to look into the Rokblokz fender extensions as well seeing if the AJK vented will work with the 2023.
108,167
Wait! Shut the front door!
Your first post and your thinking everyone already? 🤣
First off..Welcome from Michigan!
Start a welcome thread and post pics of your rig asap or your gonna get…
Pics Or It Didnt Happen!
Also if your gonna do any of what you just mentioned, you MUST come back here and report with links. Your Assholes and elbows deep now! JK but please report back and do Welcome Thread.
  • Haha
