208Talon
208Talon
208Talon
27
87
  1. Talon X4
I have had my Talon a while. I came from the Jeep/off road world. I don't really spend allot of time on forums, However I figured I would share and see what you all think. If you have questions or need info let me know.
Full Custom Cage
Dual Battery setup w/ fuse panel
Smitty Built Winch
Pro Armor Spare tie down w/jack
Pro Armor 4-point harnesses
Heated seats
After market Shift Gate
Infinity Sound Bar and JBL Sub
S&B Partial separator
Dynojet PV3
Full HMF Exhaust
Shock Therapy springs
SSS Full skid plate w\rock sliders
Tusk Lower door inserts
Super ATV Receiver plate
LED Rock Lights
5150 Lighted Whip
Super ATV Front window (modified to fit cage)
Assault Mirrors
Hess Quick Disconnect Steering hub
PRP Steering wheel
Tusk Bead locks
32x10x15 Tires
I am sure I have forgot somethings. I have lots and lots of time in this build. Most if not all of this work was done by myself. Enjoy 😊
0321211926 HDR1 03182120361 0226212225 HDR1 0505211147a1 0116211201a HDR1 0602212236 HDR1 0604212044 HDR1
Onion farmer
Onion farmer
19
94
Oregon
  1. Talon X4
How are you liking the exhaust? I need to get some on mine. Sweet rig by the way
Reactions: toddvdh
208Talon
208Talon
27
87
  1. Talon X4
I like the Exhaust. It is loud though. SO if you want stealth the HMF is not it. 😂. Thank you for the compliment.
Reactions: toddvdh
Enigma
Enigma
East Tennessee Mudder
379
858
Rocky Top
Lots of good information based on experience - the best teacher. Thanks
5,099
22,930
Since you don't spend much time on forums, check out the last post (106) in the thread linked in my sig, the X4 has a seat belt bolt rubbing through the wiring harness. The rest of the thread has some basic Talon info but you're probably well past the basics by now.
208Talon
208Talon
27
87
  1. Talon X4
Since you don't spend much time on forums, check out the last post in the thread linked in my sig, the X4 has a seat belt bolt rubbing through the wiring harness. The rest of the thread has some basic Talon info but you're probably well past the basics by now.
Will do. I saw the seatbelt bolt thing the other night. I am doing some maintenance on my machine this weekend so I am for sure going to check it out. Good info thank you.
Reactions: CID
208Talon
208Talon
27
87
  1. Talon X4
So I did take out my tunnel and look. I assume when I put my harnesses in I had zip tied the wire harness out of the way. Since that is what it looked like when I got the cover off. Thank you for the heads up. I could see how it would have rubbed.
Reactions: CID
