20ft trailer
jenk61
jenk61
153
1,169
Southern Illinois
I currently have an 18ft trailer and was looking to upgrade. I have a 1000-5 and my son has a Can-Am Commander 1000xtp. A couple of friends also have another 1000-5 and a Can-Am Defender. I was looking for a trailer that I could haul two at a time. I think according to my measurements that they will fit on a 20ft trailer unless I'm missing something. Does anyone use a 20ft trailer? Any thoughts good or bad?
63,990
20ft shown.
Compair against talon measurements.
Has 1ft to spare. 13279dd6168cc68020c65c69b54c3e9b
Ridinfool
Ridinfool
36,145
386,041
Western North Carolina
My P1K-5 is right at 10-0 long, don’t know about a commander, 20-0 trailer may work but would be tight , 24-0 will give you plenty of space for 2 buggy’s and possibly even some extra cargo, gas cans, coolers, extra tires ect. My 2 cents…
If your gonna upgrade might as well go a bit bigger just in case. I’d rather have extra space than not enough.
The #1 rule of trailers is…
No matter how big of a trailer you get, you’ll always wish you got the bigger one.
207,989
No doubt!
5,052
22,655
Yep, iffn you have room to park it, go big. Richard's pic shows @HBarlow was spot on with 2 + 2 + 2. 👍
Apologies to those tired of seeing it but here's my 10' Talon on a 14' trailer.
I f8vLC67 XL
Add a bed extender and there isn't much room to spare. Extra length also gives you working room for tongue weight adjustments.
I CLgjZFt XL
jenk61
jenk61
153
1,169
Southern Illinois
Why guess or estimate?
Measure your Honda and son's Can-Am, add at least 2' in front, between, and behind the 2nd unit. My guess is you need 24' - 26' at least.
I did measure, but without putting them on the trailer it's easy to overlook something.
Vikes79
Vikes79
SKOL!
10,998
106,794
South Dakota
  2. Talon X4 LV
Does your trailer have stake pockets? If so maybe make some extensions for the sides if you’re handy with a welder and load the Honda sideways on your 18’ trailer?
I see this done to utvs a lot in my area…
jenk61
jenk61
153
1,169
Southern Illinois
I believe that 8.5ft is the legal limit in Illinois. I would be overwidth in my state. 🙁
P
pappyo
593
2,380
Another Option: NO ramps needed
Aluma with the Power Tilt option. ( 2021 Pictured ) with toolbox on the 2ft. Stationary deck.
Tilt deck is 18ft. & there is a 2ft. Stationary deck in the front
Tungbox ( holds battery & lift controls ) <> Air Dam Is Aluma option
Side Steps <> Side Rails <> Spare Mount <> Winch Plate ( all home mfg. add on's ).
Purchased Feb 2020 <> just before price increases
You may get Sticker SHOCK Aluminum trailers have gone UP 25%.
trailer replaced was 11yr. Old Aluma 18ft non-tilt <> sold for $350.00 less for paid when new.
20200725 125538 20200725 125550 20200725 125646 20200725 125720
Reactions: ChadD and Backwoods
jenk61
jenk61
153
1,169
Southern Illinois
Vikes79
Vikes79
SKOL!
10,998
106,794
South Dakota
  2. Talon X4 LV
HAVE a Like NEW 2019 8214HST Aluma Gravity Tilt 14ft.with 5200 lbs Axle <> Going to part with here in Upstate N.Y
PM I if interested for pic &.
View attachment 339868 View attachment 339869 View attachment 339870 View attachment 339871
Tilt decks are nice till you need to load two pieces of equipment safely. Especially with the ones that have a front apron that needs to have a portion of the load over to keep the tail from falling.
I have a aluminum 18’ plus 2’ dove tail with ramps. I have to back on my pioneer when hauling it plus my dad’s Kawasucky Mule to keep the bumpers from rubbing in the middle.
I wish I had the 20’ plus 2’ dovetail version of my trailer at times.
