P500 26 or 27 bighorns
L
luger1
9
9
nebraska
Any one running 27 or 26 x9 bighorns all the way around have 25 inch original bighorns now going to put them on a atv and order new 26 or 27 original bighorns worried that 27s will rob to much power in loose sand and may rub frame but think 27 will work fine on hard pack any thoughts
Reactions: 500oneer
906UP
906UP
13,123
122,562
da Yoop
I'm running 26×9 BH 2.0 all the way around with my gear mod that raises the final drive gearing with no problem, with stock gearing you'll have no problem with 27's
Todd627
Todd627
56,452
616,554
MI
26x11 on all 4 corners.....
KxmbfKMFQZW9UbLdHHw
500oneer
500oneer
15,000 mile club
419
1,044
Central PA
I run all 26x9 I have about 3,000 miles on them,they still look new. It just started rubbing slightly at full lock when I turn right lately I’ve have aftermarket 5+2 wheels. I’ve been adding more air like 20 psi because the sidewalls get a little weaker overtime.
Reactions: Backwoods
158,806
Have ran about every 2.0 combination possible and have never had a problem pulling them. Running 28x10 2.0's on all four now. Blew through the sugar sand without so much as a wheel hop last time out. Takes a little longer to reach top speed is the only thing I've noticed.
L
luger1
9
9
nebraska
Thanks for all the input i decided to order 26x9x12 og bighorns did some measuring with the 25s mounted and at full lock has about 3/4 inch from tire to frame so i did not want to chance 27s
gmacaluso
gmacaluso
114
162
Colorado
What Trig says goes on this thread. 26x9x12 front and 11's on rear with 5+2 offset appears to be the B H 2.0 winner for the P5.
Reactions: trigger
Mudder
Mudder
NTC Ambassador of Walls
11,355
84,542
Running 27“ bighorn knock offs, Journey 350. Been a good tire.
Reactions: 500oneer
Mudder
Mudder
11,355
84,542
Journey 350 now $100 each from local store.
Reactions: gmacaluso
JCart
JCart
897
2,024
Kamloops, BC Canada.
If you carry weight, like two passengers and lots of gear more often then not.... 26” tires. If like me mostly single rider with only chainsaw, spare gas and recovery gear, then 27” tires. When you buy tires ensure they are true to dimension size many are undersized. Lastly radials are the way to go for sure. I run Kenda Bear Claws HTRs in 27x11x12 on 5-2 rims on all corners. 6-8 psi front/rear air pressure. They don’t touch frame and just snick fender at near full lock on compressed suspension, not a big deal to me. Awesome tires...
Cheers,
j
Reactions: nctrailboss
