P700 27” tire on 2016 700-2
K
Kubota82
7
15
Pa
I recently picked up a new to me 2016 700-2. It is currently sitting on 30x9x14 silverbacks on all 4 corner with 2” shock spacer lift. This is too much for my use and would like to go to a slightly more stock look. I want to take lift out and drop down to 27x9x14 up front and 27x11x14 rear. Been searching Rocky Mountain and when I search for wheel/tire combo it only gives me a 26x12 tire as an option unless it is a deluxe then it will give me the 14” rim option. My question is will the 27x14 still work on a non deluxe model. Unit is mostly work around the farm use, not trail or high speed riding. Want to eventually get plow for it also. Any info would be appreciated
Reactions: Farmer
Farmer
Farmer
2,851
16,389
Southern MO
I don't see why it wouldn't but you could try calling Rocky Mountain and talk to them. They might have some ideas/options that the computer won't show. Or, do a search on this site...tire wheel combos are the #1 topic around here.
Welcome to the club!!!!
K
Kubota82
7
15
Pa
Thanks for the info. I have seen lots of people saying 27” fit fine without the lift. Just was curious as to why the don’t list it as an option for the 700-2 and do for 700-4. Maybe since 27 is 2” larger than stock on700-2 but only 1” larger than stock on 700-4. I will try reaching out to Rocky Mountain
Farmer
Farmer
2,851
16,389
Southern MO
I run 28x11x14 and 28x9x14's on my 2014 700 with no lift. Never had a rub but I don't ride hardcore. 28's hurt the torque a little too much but not bad. But, fair warning....the #1 complaint for the 700 is it needs a lower gear. Hopefully your downsize will be good enough.
swsebek
swsebek
2,854
5,828
pa
I run bighorn 2.0s 6ply. 28/9/14 and 28/12/14 for years. They never rubbed, Till I added the mudd busters fender flares. I would catch the bolts turning tight.So I added the super ATV 2” lift.
But if you are going back to stock then 27s are your best bet. And remember just because they say 28” doesn’t mean they are.Some run as much as 1” bigger when you measure them.
Farmer
Farmer
2,851
16,389
Southern MO
To be honest..... I run the stock tires and size 90% of the time around the farm. I only put the 27's on for trips.
Reactions: Buggyman
K
Kubota82
7
15
Pa
Thanks for everyone’s opinion thus far. Sounds like nothing to worry about going with 27s and no lift. Been looking at the 8ply trilobites and most reviews I see is people saying that they actually run small compared to listed size. Gonna keep looking around at tires but sounds like going to 27 is a non issue
1950Willys
1950Willys
71
151
Arkansas
I run 27x9 and 27x11 on 12's with no problem.. The reason dealers don't list them as fitting is for liability issues and increased mechanical issues. If the machine didn't self distruct with 30" tires it will appreciate those smaller 27's .
Backwoods
Backwoods
32,369
332,219
Douglasville ga
27x10x12 on all foir and never an issue and ridden in rough places. No lift
20200821 135922
K
Kubota82
7
15
Pa
Thanks for all the advice from everyone. I’m very happy with the new look can’t wait to put her through the paces. Before and after pics for reference. Also any one in pa lookin for (4) 30x9x14 rims and tires. Let me know I plan to post them here shortly
9325FF55 1F6E 4394 B5A8 DD0DAA580D70 90396B9B B27C 4917 9029 45B7FF592A49
livefromthetree
livefromthetree
466
1,309
Mount Vernon Indiana
They are tusk terrabites. 27x9x14 front and 27x11x14 rear
I've been known to be wrong (a lot!) but I don't think those are terrabites. Looks like maybe their trilobite. If so, the tread looks like it will do a bit better in mud and snow than my Terras do although I dont have issues with mine.
Tus 16 tir tri atv rea
Reactions: Backwoods
K
Kubota82
7
15
Pa
You are correct. Trilobites my bad. I hope they do as well as reviews I read. Guess time will tell
Buckshot07
Buckshot07
19,729
203,030
X2
That’s why I asked.
Terra’s tread looks more like a light truck mud tire.
Backwoods
Backwoods
32,369
332,219
Douglasville ga
You will love them I went back to that pattern after trying all the trendy stuff. They do very well in everything
Reactions: livefromthetree
Backwoods
Backwoods
32,369
332,219
Douglasville ga
Isn’t the trilobite tread pattern similar to the pattern of the stock P1K tire tread?
Yes , everyone duplicates it . It has always been a great performer.
