P1000 28 inch Tire Question
Mossygoose
16
Greenfield, TN
Can I put 28X10X14 tires all the way around on 2016 Honda Pioneer 1000-5 with no issues? I also just found a set of Honda Talon wheels with tires 28x8x15 and 28x11x15. Tires are 90%, I can get them for $300
Received 1286047542051925
NTCPrezJB
NTCPrezJB
President of #NTC
100,629
899,200
Canton, OH
Front and rear stock rims are different widths, but if you’re talking aftermarket rims…yes most say their 28’s fit without issue.
All “28’s” are not created equal though.
105,620
Welcome from another Michigander!
Nice buggy. Are u first or second owner? If you havent already, Id use the search up top for tires AND issues and recalls of that there 16’ you have. We k ow a thing or two cuz weve seen a thing or two;)
Scoop
Scoop
4,214
15,741
  3. Talon R LV
If you're not ready to spend some coin now, I'd go 28x10x14 all the way around on your stock wheels and suspension.
If you're ready to spend - or if you want to save up to spend - upgrade your shocks (Fox QS3) and your A-Arms (SATV high clearance 1.5" offset A-Arms) then go with 30x10x15 tires on 15x7 5+2 wheels (and the RB3 wide track spacer kit) all the way around.
Fox shocks: There's a trick to getting them cheaper from ronayers.com: Create an account, log in, THEN add to your cart.
1698108289141
P
packer58
301
908
N. Cali
28-10-14 Interco Snipers on stock wheels ........zero problems after 600+ miles ....
Reactions: Robobrainiac
Scoop
Scoop
4,214
15,741
  3. Talon R LV
Hmm ... so is that like 1200+ miles, @packer58? 🤣
  • Haha
Reactions: Backwoods
P
packer58
301
908
N. Cali
Good catch @Scoop, not sure about the double post .......could have sneezed at just the wrong time ...Dunno
Travis R
Travis R
135
441
Southeast Louisiana
I put 30x10x14 High Lifter X Comps on my 2016 Pioneer 1000-3 today. It has a 3” lift kit. The 30s rub some in the front when I turn, but it’s not really a big deal to me. If I’d of known they would rub, I would have bought 28s. I love the tires though. I don’t mud ride, those days are over with. I mainly ride on gravel roads and asphalt.
Love Honda and my Pioneer too! 👍🏻
Bombardier Convert
Bombardier Convert
324
1,110
Minnesota USA
I am thinking about getting new tires and wheels for my completely stock HP1K-3 Deluxe with 14 inch rims. I have close to 2900 miles on the original Bighorns and the lugs are wore down about half or a little more. Summertime I run alot on county secondary blacktop and dirt roads and some dedicated atv/utv trails. Springtime and late fall I am in some mud and softer ground wooded trails. I plan to save the original tires and wheels for spring/fall use and put on the new tires/rims for Summertime road running. The original Bighorns are 27 inch. My question is will 28 inch terrabites fit without rubbing? Some say yes, some say maybe not? I saw a YouTube that said they could rub on tight hard turns. Before I buy I would like to be more sure that the 28 inch Terrabites would fit without rubbing.. thanks for any and all help with this...
Travis R
Travis R
135
441
Southeast Louisiana
I have 30x10x14 High Lifter X Comps on my 2016 Pioneer 1000-3, with a 3” lift and they rub when I turn on flat ground, or go across a ditch at an angle. I love the tires, but wish I’d have bought 28s. Next time I will. NOT ALL TIRE SIZES ARE EQUAL.
