P1000m5 29" Tusk Terrabites
P
PineTree
61
75
Andover, IL
Anyone running 29x11x14 Tusk Terrabites on aftermarket wheels on all 4 corners? I know the Tusk tires run a little small and I've read several places that guys are able to run the 29x9x14 up front with no issues at all. But I think the wider 11" tire would look better and I'd be able to rotate the tires for better wear.
Reactions: Lady01
Ohio4x4
Ohio4x4
I brought the dishwasher
1,495
15,026
Ohio
The wider front tire will make it harder to steer. I had 28-10-14 outback black max on all 4 corners I recently went to what's listed as 28-9.5-14 and had a noticeable difference in the steering feel.
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
DSCN2039
IMG 20200321 190624656
IMG 20200320 122207763
107,308
If u go that route, might want some spacers to help with that.
GPR1500SC
GPR1500SC
857
2,355
North East MO
  2. Talon X LV
I am running a inch spacer in the front and a inch and a half spacer in the back.
SATV 1.5 set forward A arms Rhino 2.0 axles no steering stop's.
The side wall of the tire does rub on the A arm, but I don't mind the few times it does is because I am stuck and getting desperate or backing around in a tight spot.
I have never noticed any power steering issue because of the width.
Reactions: PineTree and Lady01
