30" or Larger Tires?
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
Welcome to the Club @rrabaca73 !! I am running 28's.
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
Thank you @Tflynn !! I thought about telling him about these guys too but like you said I wasn't sure about the issues that they may or may not be running into.
Reactions: Tflynn
Had 28 with 3" lift they rubbed when turning and the wheel was tucked.
30's are gonna rub but you can fit them with a 3" or bigger lift.
dubsdime00
dubsdime00
7
5
I'm running 30x11wide all around, have the Xtreme 3" lift
20151024 164343
scott
scott
1,212
1,354
lyman, South Carolina
I really think 30" and bigger is too much for the 700. Even with power mods i wouldn't do it.
39,079
With my 28" tires, there were some rocky hills that it wouldn't pull and some mud holes that it would spin the tires in 4-lock. Also, I had a custom exhaust, K&N, and tuner.
For the most part, I like the 28" tires and would put them on again on a P700 but it would suffer with 30" tires in my opinion.
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
30" tires with a gear reduction portal lift would be the ticket, let me go grab $4000 and do it
39,079
$4000?! Give me two sets and I'll double the gear reduction and lift.
Reactions: Tflynn
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Why stop there? How about five portal lifts and monster truck tires?? Hahaha!
39,079
I like the way you think!
Bigfoot 5 gentlemen
I think the 700 is a little under powered to run 30's on steep rocky terrain or deep gooey Alabama clay.
General trail and deep waterholes yeah. 28's were doable but not 4-up on rocky ledges. It didn't have the torque to climb them with 1000lbs of meat onboard.
Reactions: joeymt33
39,079
Have 27" on mine. . Just put spacers on shocks, 2" lift. . Runs and does great
I had 28" tires and I think that is max because the engine struggled on steep hills and they rubbed the firewall. If you want 30" tires, plan on some custom forward arched A-arms, lift, and power adders.
Reactions: Tflynn
Gator
Gator
The Most Unknown Member
2,474
10,376
Louisiana
I don't understand. My neighbor has a Polaris 570 with 32" tires. (A-arms and lift) That machine turns the 32" tires. I've witnessed it in some deep thick mud. Why won't my Honda handle it and what would I need to do to get there?
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
My guess is that 570 has more horsepower. The 700 has I believe 33 hp, not much for 700cc but to me that explains why the engine has such great longevity and reliability.
What do you need to do to get there? Winning the lottery would be a good start! Haha but seriously, a portal lift would be the simplest way to successfully add 32" tires. Otherwise you'll need a big lift, forward a-arms, and probably looking at a turbo. So like anything, it can be done, just how much will you want to spend?
Tflynn
Tflynn
Not a liberal
2,502
3,844
Northern California
Also, with that added power and tire size an axle upgrade will likely be necessary
