Multi 4/110 to 4/137 wheel adapter needed!!!!
Tramguage1
Tramguage1
Texan
7,182
27,659
Somereset, Texas
As the title says, im looking for 1 wheel adapter to go from a 4/110 lug pattern (700&700-4) to a 4/137 wheel (1000)
If anyone has one or has a idea who i can contact. Hit me up.
Tramguage1
Tramguage1
Texan
7,182
27,659
Somereset, Texas
Thats exactly what i need it for! I am reusing my rear tire carrier from my 700.
Tjanks for the links!
Tramguage1
Tramguage1
Texan
7,182
27,659
Somereset, Texas
These are just spacers. Center bore is 110mm. Lug pattern is 137mm. Ill keep looking.
267,224
The hub centric hole is 110. not the studs.
Cant believe I missed that
Download
Reactions: Hondasxs
Tramguage1
Tramguage1
Texan
7,182
27,659
Somereset, Texas
Im still looking.
Thanks for the help
Neohio
Neohio
Beast of the East
13,475
66,490
Painesville Ohio
This is for your brick city cargo thingy right?
Maybe a quick call to Moses and get a new plate and weld it on?
Is drilling a new bolt pattern an option? Then hit your local parts store for some honda civic/accord replacement studs?
If you throw up a pic of the mount, we might be able to offer dirt cheap solutions.
267,224
Im still looking.
Thanks for the help
Just thinking out loud, for it's purpose you need, wouldn't it be simple to get a 4/137mm 1" spacer and just drill the 110mm pattern for the tire carrier?
Neohio
Neohio
Beast of the East
13,475
66,490
Painesville Ohio
most of the spacers I have seen @JACKAL have huge ID bores to help with weight. Might not be enough meat to bore new holes.
Reactions: JACKAL
267,224
Good point.
Neohio
Neohio
Beast of the East
13,475
66,490
Painesville Ohio
Possible Solution!
Refer to my ace drawing skills.
Tire
Grab a ruler and see if you can drill holes where I indicated, then press in new studs, or tack weld them. (pic stolen from your for sale thread)
EDIT: Going to add this here as well. what if you knock out all those studs, add 2 studs, say between 1/2 and 10/11. Hang your spare using the holes beside each other vs opposing or all 4 studs?
Reactions: JACKAL
Neohio
Neohio
Beast of the East
13,475
66,490
Painesville Ohio
Any update on this @Tramguage1 ?
I just did a rough sketch. If you go side by side wheel studs, they need to be 3.814" from center to center.
Reactions: Tramguage1
Tramguage1
Tramguage1
Texan
7,182
27,659
Somereset, Texas
I have looked at redrilling holes and reusing studs. Only problem is the spare rim has more offset that the 700 had. So i need to add about 1" to the bracket so the 1000 wheel will fit correctly. I reall y dodnt think it would be this hard to find a darn 1 " thick wheel adapter.
