Well, depending on which 2... like.. the front left, and rear right? That could be a problem. š¤£Just got a notification that 2 out of my 4 tires are back ordered until the end of Aprilš©
I'd have to go back and look at old posts to see where I was with the different setups. I want to say with 5+2's and 26x9 I was at 54" in the front. The rear was close enough to even running 11's. With same size on all four I had to put 1" spacers on the rear to even the track width.
I have 5+2 with 26x11x12 on back and 26x9x12 on front. I'm at 52" on the front. The back is 53".
Again I wonder where everyone is measuring from? These numbers will vary depending on psi and the given day, my measurements have slightly changed from one day to the next. I'm probably getting more bulge at the bottom with 28's. The point I was trying to make is that you don't need to spread the stance that much to get stability. I'd assume yours feels comfortable at 52" with 26's?
