P1000 4 wheel drive not engaging
208,029
Well i am going to be the bad guy here.Nature of my past jobs.Your snap ring looks like it got the dog s*** beat out of it.It seems the inner piece and the outer piece are walking back and forth way to freely. It could be to loose of a fit. That was a good find and thanks for the knowledge.Maybe try a different gear oil to slow down the movement.Iam sure you found the problem but why.That was my job to find out why.
Looks like the old clip is cupped?
T
tbwolf
23
105
Pennsylvania
I agree that it’s odd and I have no clue why it popped out. The old ring is beat up but from what I can tell it was just sitting there taking abuse from the rear driveshaft constanly spinning.
Nothing else seemed impacted by the issue.
It’s all back together and worked great on a test run last night!
I guess if my 4wd goes out in WV I’ll have a good idea what’s wrong.
If it happens again I’ll most likely replace the front section that houses the 4wd arm, shaft, bearing and snap rings.
108,159
Good time to Put the synthetic gear lube (NoBudLite) in the diffs to quiet er down a bit while your in there
T
tbwolf
23
105
Pennsylvania
Forgot to add that... I put the valvoline full synthetic 75w-140 in yesterday after reading about it quieting down things.
ODAMO
ODAMO
1,177
3,206
Ohio
Good luck on your ride. Sounds like you got it solved. How many miles do you have on it before the problem? Wondering if the ring was misinstalled or something else like @john 790 said
