4Runner Build
popeye
popeye
3,273
14,642
kapowsin, Wa
4.88 is the lowest they have for the rear so 4.88. Ford went to a 37 spline pinion that year so not many options yet.
4.88 was the stock ratio in the mid 2000s f450-550s I believe, is that what the rear is sitting with now? have you ran the gear ratio through any calculators to see rpms and speeds of each gear?
If not this is a handy site that will help
http://www.grimmjeeper.com/gears.html
Sent from my XT1565 using Tapatalk
Reactions: sharp
popeye
popeye
3,273
14,642
kapowsin, Wa
Some info if I set it up right? 4l60trans 241t-case, 4.88, spinning 40s? Is that right? D2ac82d884aeeeb2d612a250b77daee02b405c0849989413306b077c0f80fd7f964e4a39916a7ad7886f36adc873e86f
Reactions: sharp
snuffnwhisky
snuffnwhisky
Village Idiot
3,305
18,157
Cullman, AL
  2. Other Brand
3.73 in the rear right now. 4.88 is pretty good. I believe I was around 2k at 70 in OD.
Reactions: sharp
snuffnwhisky
snuffnwhisky
Village Idiot
3,305
18,157
Cullman, AL
  2. Other Brand
Also running a 4L80. Has a .75 od vs .70 on the 4L60.
snuffnwhisky
snuffnwhisky
Village Idiot
3,305
18,157
Cullman, AL
  2. Other Brand
37" Tire
4.10 - 1,950 RPM @ 70
4.88 - 2,325 RPM @ 70
40" Tire
4.10 - 1,800 RPM @ 70
4.88 - 2,150 RPM @ 70
The front currently has a 4.10 gear. I can get a 4.10 for the rear also.
Ordered a cam yesterday from Texas Speed.
212/218 @ .050", .600"/.600" Lift, 111 LSA
PAC Beehive Springs
Hardened pushrods
New lifters
437.3 HP @ 6200 RPM/417.8 TQ @ 4800 RPM with headers, this cam and a tune on a stock 5.3 on their dyno. Right at 350 ft.lbs. at 2,000 RPM
Will be doing some head work and possibly more depending on what the motor looks like when I get it apart.
Reactions: sharp
snuffnwhisky
snuffnwhisky
Village Idiot
3,305
18,157
Cullman, AL
  2. Other Brand
Have you thought about moving the front end forward? Might take less trimming of the inner wheel wells, plus the added wheel base might give better manners when towing the pioneer?
I did. Have about 8" from the tire to rear fender.
snuffnwhisky
snuffnwhisky
Village Idiot
3,305
18,157
Cullman, AL
  2. Other Brand
Ditched the front frame and started rebuilding it. Wasn't enough clearance for the driveshaft, exhaust and links.
IMG 20171201 212223265
Got a hydroboost and 1 ton master.
IMG 20171209 012959054
Engine is rebuilt along with the trans and Tcase.
IMG 20171209 012936584
Yes I prefer separate switches but my HZJ77 has this little dial from the factory
What’s the stand RR for? I know front and rear and I know it’s for the lockers but they have some extra R’s there.
Reactions: BWAF
